wildbansheeboy
Everything posted by wildbansheeboy
  1. My timing is +7 carbs are 35mm air strykers .I also run a stock rear sprocket and a 15 in front.my rear tires are 22 inch zippers. My pipes are cpi inframes. I got a lightend fly wheel that is not installed yet but it will be in by the next weekend .The fly wheel should make my shee a little quicker. If you all have any idea's on how I can shave any time off let me know :thumb: I also run 108 octane race fuel and my head is shaved. My reed cages are stock with after market reeds.(next v force 3 ) :biggrin:
  2. What is a good timed run on a 300ft sand drag track With a stock crank,drag ported ,drag pipes and a few other goodies? I am just trying to see how my shee compares to the rest of u shee freaks. My best is a 5.022 :beer:
  3. ATV Drag Race & Mud Bog Saturday, June 17th and September 2nd Rain Date: Saturday, June 24th and September 9th 15 Drag Classes from 50cc to 800cc for Utilities to Sport Mod. 6 Mud Bog Classes for all ATV's. Drag Race Registration: 8:00a.m. to 10:00a.m. Race Time: 11:00a.m. Mud Bog Mud Bog: 4:00p.m. Mud Bog registration runs till 3:00p.m. Located: 1/2 Mile West of Strum, WI on CTY RD. V 30 minutes south of Eau Claire, WI. Easily Accessible from the Buffalo River ATV Trail. ***The Drag Race takes place on a 300ft. dirt track. The race is a side by side double elimination. Trophies are awarded 1st-5th place for both the drag race and mud bog. Each mud bogger will have two timed runs. The times will be combined and fastest combined time wins.**** Pkease respond to this post if you have questions. Hope you can make it to the event.
  4. DAN AT A&S (DID MY PORTING)SAID THAT IF I WANT TO USE INFRAME PIPES TO GO WITH CPI PIPES TO GET THE MOST OUT OF MY PORT JOB.NOW BACK TO MY POST TOPIC .WELL I DID NOT GET MY STEEL CPI INFRAMES THIS WEEK.CPI TOLD PARTS DIRECT THAT THE PIPES WERE SHIPPED TO THEM AND THEY GOT LOST IN SHIPPING SO IF I WANT STEEL INFRAMES IT WILL BE 2 WEEKS BE4 I WOULD HAVE THEM . I TALKED TO PARTS DIRECT ON FRIDAY MAY 19TH AND SAID THAT THEY HAVE CROME INFRAMES IN STOCK .SO I UPGRADED TO THE CROME ONES AND THEY SAID THAT THE PIPES WILL BE SHIPPED FRIDAY AFTERNOON.SO I HOPE I DON'T HAVE TO WAIT ANOTHER 6 WEEKS 4 THEM.
  5. How long did it take be4 you got them?
  6. I ORDERD A SET OF CPI INFRAMES ON 4/7 FROM PARTS DIRECT 1-800-220-7005 AND I STILL DON'T HAVE THEM.PARTS DIRECT TOLD ME 2-3 WEEKS BEFORE I WILL HAVE THE PIPES WELL IT'S 5/11 .I HAVE CALLED PARTS DIRECT MANY TIMES AND THEY KEEP TELLING ME 2-3 DAYS BEFORE THEY WILL HAVE THEM WELL ITS BEEN 14 DAYS.I CALLED PARTS DIRECT ON MONDAY 5/8 AND SAID ANYTIME NOW(I HOPE).HAVE ANY OF U GUYS EVER GONE THROUGH PARTS DIRECT 4 ANY PARTS? ARE THE GUYS AT PARTS DIRECT FUC=ING WITH ME OR IS CPI THAT FAR BEHIND ON PRODUCTION? I SURE HOPE THE PIPES ARE NOT SHITTY LIKE THE 1'S I READ ABOUT ON OTHER POSTS!
  7. I got a adj.timing plate and a flywheel puller.How do I install the plate?
  8. My mod.banshee whooped a 2004 honda 250r in a drag race over & over & over
  9. Yes u can use diesel to clean your chain and no it will not hurt your o rings.I have 5 diesel tractors and o-rings are used in the fuel systems to help seal fittings.
  10. Hi,Any of U drag racers ever try a motor set up for low-mid power(all the goods) . 4 300ft drags? Would this work good or not?
  11. r LRD ADJ. PIPES any good on a drag ported shee
  12. Man U guys are fast tonite thanks to all.
  13. WHERE DO I GET A SET OF TDR REEDS 4 MY SHEE
  14. Contact PRO DESIGN I had the same deal on ebay a head with no studs check thier web site 4 phone # .The studs are not cheap but use the right ones or u can cross tread real easy.
  15. Do reed spacers help HP ? what size 3/8 or 1/2 inch ? what side of reed cages is best 4 top end ?
  16. I have a shee that has a drag port done to it and bored 30 over ,35mm air strykers,v-force reeds ,and a few other mods,I have a buddy who has a set of cpi out of frame big bore drag pipes . I was thinking of putting them on my small bore shee will I gain or lose power? Just checking to see if anybody has ever tried this before I try this .
  17. $
  18. I agree V FORCE 2 are the best .I use lock tight on the screws so I have no worries about them coming loose
  19. How do I contact KD cycle or f.a.s.t racing to get a coil
  20. I used amsoil 100 to 1 for many years in my moto-x bikes and my shee and never had any problems from running lean its a good oil but watch your plugs to see how lean or rich u are and might have to rejet
  21. I have some ? on nitrous .First is nitro a big power boost? Is the kit hard to put on the shee? what will need to be done to the jetting,timing,and gas ratio is there any thing else that needs to be done? NOW WHAT ARE THE BAD THINGS IF ANY?The nitro kit is $540 is that a good price or is there a used 1 around 4 sale please let me know all good and bad.
  22. I plan on talking to Dan to see if I can run my jugs can be run with a stroker.When the porting was done I was not planning to go any bigger but know I need to keep up with my local drag racers who are getting a little faster.Will just a big bore kit help me alot or just a little (How many HP)
  23. I plan on doing both but what is the best way to start by stroking my shee or big bore .My jugs already have a port job stage6 by dan hull at A&S what will I need to do to my jugs if I go stroker first. my main use of my shee is drag racing .
  24. K&N CLAMP ON FILTERS WITH OUTERS IS THE BEST WAY TO GO UNLESS IT'S WET OUT!
