taldoc3
Everything posted by taldoc3
  1. I just got through installiing v-force 2 reeds, I removed the carbs and unscrewed that tors.s crap, got it all back together the way it came apart, now when i start it the shee is stuck wipe open, throttle has no play in it you can feel the springs on the tors they have tension any ideas
  2. dig deep in the pockets for 80 hp
  3. just let it stick and ride it till the wheels fall off
  4. noss all the way man, good price, great guy to deal with, member discount, different colors, oh yea he is an okie also
  5. do you have the small spacer and c-clip on the right side of the axle
  6. spend the money and get the v-2s' I had boysen on my shee, made no diff whatsoever, just wasting green with the boysen reeds
  7. you have your locknut backwards, if you rad the directions on how to install this will happen, the dir are not easy to understand, if the locknut is on right it is impossible for the c-clip to come off, also make sure you have thread locker on the tension screw, the one with the alan head or else it will come out also and allow the 3 pieced locking nut to back off
  8. get an adjustable timing plate from ricky stator 35.00 plus shipping oh yea and a flywheel puller
  9. i had this same thing happen, check your upper a-arm, by the ball joint where it flattens out, see if it looks like your other one, this could be bent slightly, mine was bent real bad and the top of the tire toed inm took it off got a bigger hammer and now good as new, I was on a wheelie when i did a dingleberry and the bike fell on the the right side bummer
  10. tighten the a-arm bolts tight enough where they won't come off
  11. noss head man david noss is a great guy to get heads from, just got one and it thumps like a wild banshee lol
  12. the samw happened to me, yes all your parts will fit, the reason I went with a g-force is because it has a true lifetime warrenty, I was going to buy a durablue and actually was on the phone with rockymountainatv.com when I had a change of heart, the guy on the other end said durablue had made some changes to their policy, he said you could bend,break a durablue axle and the first exchange was free, thereafter they charge you 175.00 per break or bend, g-force says in their policy they will exchage as many times as necessary and you get out about 80.00 bucks cheper. I love my g-force, I jump alot and high also never had a prob. I would highly recommend g-force instead of BENDABLUE.
  13. yep
  14. taldoc3
    Dynatek
    dyanatec always taakes care of there peps
  15. how tall do wips have to be I broke mine and redone it its about a foot shorter than it was
  16. taldoc3
    Gearing
    15/41 wprks well for me
  17. elka does the best
  18. 6000 hp ? lol
  19. i don't know either but there not shee's anymore
  20. yea its the 17th.
  21. look in sept. 05' issue of dirtwheels pg.223 and let it explain
