JArmShee
Everything posted by JArmShee
  1. So basically i want to get the largest size main in as possible. (Without bog obviously) Sorry about all the questions if the shees were fuel injected i could write a book on them. Thanks again. BTW we were talkign about plugs and oil a few days ago Its a B8ES NGK and I run full synthetic Golden Spectro. I went to 32:1 and the smoke is a light hase. Anthony
  2. sorry.. So go to 170. If it bogs, go down to 167. if that doesnt bog go up to 168? What if the 170 doesnt bog? 171? Thanks Anthony
  3. Pro design head 22cc domes.(Sea level Pump gas) 33mm Keihin Carbs, Stage iV manifolds, Tommey T5 pipes. Reed spacers Power reeds, Boost bottle, Sprockets 13F 42R. I want to double check but im 99% sure its a 165 Main.
  4. I drained the tank and ran 32:1 yest.. Much better. But I feel like it should have more punch in power band. For all the work done to it I feel like I should be getting thrown off the bike. Its not studdering or having problems starting. Clean through out all throttle positions. So is it I was just expecting more compared to a stock banshee. should i rejet?
  5. its 2.55 for 93 here in NY.
  6. Im going to run home on my lunch break in an hour or so. check my plug and Brand of oil. Thanks for your help Anthony
  7. Forgot the brand. But its full synthetic.
  8. lol yea . I think ill drain the tank and Change the plugs..Should 40:1 with full synthetic be ok or should I go 32:1
  9. yea smokey. not bon fire smokey. but a little too smokey
  10. well heres one i know. The BR8ES is standard. The BR9ES will be colder The BR7ES is hotter Use the plug that goes with the normal operation of your shee. using incorrect heat ranges can cause plugs to foul over heating and piston damage. Use a high heat plug for low speeds and low temps. And a cold plug for high speeds temp and engine loads.The plug should be hot enough to burn off deposits fuel etc. but not to hot where it may burn holes or predetinate.
  11. so in other words 24:1 is wayyyy off
  12. I also had to change the side gate to get the quad in and out. Any time you have to get a bigger gate to fit your new toy in your yard. You bought a good toy. I couldnt do the compression test. None of the adapters fit. It runs good just a little smokey. I did 24:1.
  13. I put it in the other one relized it was in the wrong forum. Put it in this one and by the time I got back to remove the other one, someone had replyed. My bad. And I would have to guess no on the Rejet. What is your mixture.
  14. ok so what should I run. with synthetic
  15. Thanks
  16. Went from 20cc and race gas To 22cc and pump gas. Should I rejet?
  17. My shee had 20CC domes and ran on race gas I just switched the domes to 22cc. and run 93 Octane. Should I rejet?
  18. Whats a safe mixture for a pump gas Modified Shee. I use Synthetic. I went by clymer which is 24:1 Just wondering if I should change since the Shee is modified.
  19. ok can you send pics my email is above thanks
  20. Theres something no one has thought of.
  21. SHAGGY SEND PICS TO [email protected] HOW WOULD I SEND YOU MONEY. CHECK MONEY ORDER?
  22. Tank plastics. (White or Black) Also looking for shock socks (covers) Black or White Hand grips. (White Black) Race cut Fenders. (Black or white) Let me know what you have Im in NY Thanks, Anthony
  23. WHATS THE WORD IM LOOKING FOR? GAY? ..yea yea thats it.
  24. Thats the way I figure it. Ride till it breaks. Then rebuild better
  25. oo my bad misread your post when you said you brought your shit home I thought you meant your shee.
