It's all good... I had to think, I have a dyna and nology coil...but, my cub did run with over 180PSI on stock counterparts....and ran good before I messed it up....
:beer:
When you say the plugs are tan, that really doesn't mean much. New plugs can take a while to color, etc.
What matters is how the base of the insulator looks after a 4-5-6 WOT Run on fresh plugs.
Bascially, I agree....but I'd still change the plug gap unless you're running mucho compression or alky.
As long as your compression is ok, and the carbs aren't way off...which they don't seem to be, I think it's either coil, stator or CDI. Normally, I'd rule out the CDI because MOST of the time when they fail, they just stop working, period.
Ohm the stator and Coil...see where that gets you...
Here's another few long shots...
Make sure the screen in the tank isn't clogged (fuel valve)
Make sure the gas cap is venting properly
Make sure the vent tubes on the carbs aren't clogged
Re-Check all grounds, if the ignition isn't getting a proper ground...it could heat up more than normal after a bit of riding and fail.
Good luck...
