slow2_2
Everything posted by slow2_2
  1. I had a similar problem and I swapped the carbs and the problem swapped as well. So I rebuilt my carbs and now everything works fine. I have also herd that a faulty cdi could do that as well.
  2. I have reciently purchased the Ricky Stator and adjustable plate and set the timing to +4 degrees. Now the bike is very hard to start and it seems that I did loose quite a bit of low end. I was wondering the the best timing would be for a trail bike with 28mm carbs., 1/2 reed spacers, boysen reeds, pro lite pistons, fmf fatty's, and high rev. cdi. would be. I just want the low end back and make it easier to start with all the power I can get. Thanks
  3. I would like to find the intake and possibly the boot or the complete setup. Im looking for better low end and better fuel economy. Let me know what you got.
  4. I could use a little advise on a few tips. Has anyone come up with a trick to make the clutch pull a little easier? How about the throttle. What kind of jetting and fuel mixture should I run with a set of 28mm mikuni's, fmf fatty's, reed spacer, std. pro lites, and boysen reeds. My bike runs real good but it smokes alot and gets very poor fuel mileage. Please help with some advise. thanks
  5. slow2_2
    2 in 1 intake
    Im looking for a 2 in 1 intake for my shee. I already have the carb and I'm looking for the intake. I do have some 28mm mikuni's and stock carbs to trade if anyone is interested. If no I would like to know how much.
  6. I still need a left upper a-arm but i also could use some silencers for fmf pipes.
  7. Im looking for a left upper a-arm for a 97 shee. Im hoping I could find one cheap and gray in color. Pls. no bends.
  8. slow2_2
    need cdi
    i've got one that came off oif a running 96 shee. I'll sell it for 50 bucks plus shipping
  9. How much for the silencers if you still have them?
  10. How much for both upper control arms shipped to zip code 63775?
  11. Update; I barrowed a cdi unit from a friends bike, didn't help. I pulled off the reed cage off of the side that is not hitting and the reeds looked good. Which that are fairly new anyways. I will switch the carbs sometime soon to see if that will help.
  12. What would explain the fuel comming out to that side exhaust pipe?
  13. Alright, I have been running in a series of problems with my shee. First, I couldn't get it to start without using carb. cleaner. I wasnt getting any fuel, so I purchased new carbs. and now it will fire right up. The problem is, it will only hit on 1 cylinder. I have switch the plug wires around, swapped plugs, and even check compression, which is good. I know I am getting fuel because it sprays fuel out of the exhaust. I pull the plugs out and the one that is not hitting looks brand new. Does this sound like a cdi unit problem? What else should I check. I am mechanically incline but fairly new to the shee. I'm used to working on vehicles.
  14. slow2_2
    Carb cap screws
    I am looking for some adjuster screws for the top of my carbs. I have 28mm mikunis with tors elliminator, but am missing the screws that the throttle cable is supposed to fit in.Does anyone have any extras, or know where i can find some.
  15. I know that the throttle cable for carbs with the tors and without the tors are different. I have been to motion pro and rocky mountians websites. Which cable cable is the one without tors.
  16. I am looking for a throttle cable for aftermarket carbs without the tors. Does anyone know where I can find one and where I can get the cheapest.
  17. How much for the flywheel shipped?
  18. slow2_2
    Carbs.
    Im looking for some aftermarket carbs. 28mm or the 2 in 1 carb set up. Let me know what you have got. Thanks
  19. I am looking for stock exhaust clamps and mounts for the pipes if you have any. Also looking for some aftermarket carbs for std. bore engine. R/upper a-arm, silver in color. Let me know if you have anything and prices. Thanks.
  20. I am also looking for some exhaust clamps and mount for fmf pipes if anyone has some.
  21. got an upper control arm
  22. Im looking for some aftermarket carbs for my banshee. I do prefer the 2-1 carb set up but will settle for duals. Also a friend of mine is in desperate need of a right upper a-arm for his raptor. Reply soon.
  23. I'll give you 30 shipped for the slightly bent nerfs right away if you are interested. Let me know asap. Thanks
  24. I am very interested in your pipes. What series are they, condition and color. Let me know asap please.
  25. will you take 50 bucks for the pwk's? if not how much you want for them? do you have any aftermarket pipes?
