wimpywade94
Everything posted by wimpywade94
  1. I think you may end up with crank and case seal problems if not done very carefully though, wade
  2. yeah I ride desert and dunes alot so im going to go with mabey some wicked arms or something, thanks for the help guys, saved me some time and money by not just bidding away on some! wade
  3. Can anyone tell me for sure if works dual rate rezzie shocks will work with yfz arms? I should think they would fit and bolt up, and when i have the shocks rebuilt Ill just have them built for +2 arms. Anybody have a reason why this wont work? wade
  4. I had to flat burr type bits that came with my dremel, and i used those the rought cut the shit out of the cyl. then i took diff size sanding wheels and cleaned it up, then lots and lots of time with sandpaper, water and beer, But mine came out good, really cleaned up the bike. wade
  5. I can not belive that this thread got to be this long.
  6. Thanks for the offer, Sounds like a good deal but the case if for my buddie and he dosent have that kind of cash, i think i found just the case for 40. wade
  7. Hey all, I still need a case for a yamaha blaster, Its the right side, or the kickstart side depending on the angle you look at it from, Need ASAP! Last thing the bike needs to be put back together. thanks Wade
  8. my plan was to buy the works shocks off the warrior and send them in to get them rebuilt for +2 arms if that was possible, what are the differences between banshee and warrior shocks?
  9. hey guys, 2 questions, if i bought some works shocks that were for stock a-arms and used them on +2 arms, would they work or would they be to short, and will warrior style works shocks fit a banshee. thanks wade
  10. Hey all, just curious if there is any way to rebuild a rear shock yourself, or should i save the cash up and send it it for a rebuild. and do you have to take the shock apart to get a new spring on it, or can you do it with the shock body intact. thanks wade
  11. Mabey he could have sold it for what he wanted if he would have told what was done to it besides the fact it was a long travel banshee with a BOOST bottle. wade
  12. cool, thanks guys. wade
  13. Hey all, ive searched and didnt turn nothing up, Will boring my bike over .030 lower my compression? I have a coolhead, dont have the domes yet, i plan on running 20's, I know there are a TON of variables to the question, so my main question is will the oversize piston lower my compression alot? wade
  14. any idea what the cost to rebuild and revalve to a diff weight is? I may be interested in them. wade
  15. I still have a stock one also, a bit weatherd but will do for now, Thanks though wade
  16. dont waste your money on the billet timing plate, just get the the regular adjustable, your never going to see the timing plate so no use in wasting money on billet. wade
  17. HEy i need the swingarm skid, and DESPERATLEY need the chain tensioner. Let me know i can paypal right away! wade
  18. Hey all, I need the stock chain tensioner setup, i know mine is toast but i havent pulled it yet, should have all of my other parts here by thursday and my vacation starts on sat, so i need to get the last few critical parts together to finish my build! thanks wade
  19. cool, thanks for the info bud, i found one on Ebay. wade
  20. fair enough, I think im going to try the ebay porting and get the dune port, and at the same time have the crank welded. thanks for the eye opener guys, wade
  21. Hey all, Im in the middle of rebuilding a banshee i picked up last month, Ive already got a set of t-5's im working on getting polished up, and i got a set of pods for it last week, , i just orderd a weisco ultralight kit, a coolhead, and a adjustable timing plate,ill probably run a 20cc head, im at about 800 ft above sea level, and will be riding in 90+ deg all summer, I dont mind running a mix of race and pump or even full race. I need to true and weld the crank, and will most likely have that done now. I also want to get some porting done on the motor, if i get the crank welded and get the bike back together, can i wait for a few months to get the porting done, and ride it with the new top end., then use the same top end when i send off the jugs for porting? or will i have to get a new top end set again? thanks guys wade
  22. Hey all, one of my buddies i ride with does not have a helmet, Im going to buy one from him for christmas, thought i would check here to see if anyone has a extra one sitting around in new or near new shape, Needs to be either xl or xxl. Thanks guys wade
  23. I need the stock chain tensioner and rear skidplate.
  24. Send some pics, I dont think its a common problem, i think that when he put his cases back together he broke it, How much you want?
  25. Hey guys, im just getting ready to put my banshee and my buddies blaster back together in a few weeks, and Im still havent found a rh blaster case for his bike, the kickstarter broke the case, If anyone knows where one is for cheap ill take it off your hands, and is there a fix for the kickstarter problem on these bikes, seems like ive seen a few with the problem. thanks wade
