dragbanshee02
Everything posted by dragbanshee02
  1. it is aluminum but it does not say dg on it anywheres it is the one out of the 2002 yamaha catalog. I believe it is made by DG they just don't put there name on it it is a satin finish sorry forgot to add that but it should not polish to hard if you would like to when you get it.
  2. the bumper on the yamaha website now is not the one i have it looks identical to the dg just with oput the name plate in the center. Hows 65 shipped the thing looks brand new was like 100+ new.
  3. anyone? I also got a uni filter stock nerf bars the plastic pieces too. complete stock exhaust airbox with gutted lid. and 2 sets of carbs one stock set and one 38mm set. make offers.
  4. wow i must have really ripped that guy off if only i could find where i put them (damb girlfriends cleaning your room) he gave me everything that you are offering for 40 shipped.
  5. I got the aftermarket front bumper from yamaha I belive it is the same as a DG but with out the name tag or plate across the front in the center. I got alot of other stuff to I went all ou t drag so i got alot of stuff as far as wiring and switches and whole pile of stuff i took off that i don't need. The bumper is like brand new make an offer and don't be afraid to ask if i have something too i might just have it I also have a set of aftermarket foot pegs round style if anyone is interested
  6. these pistons are also good for classes wher you can not run porting as they simulate having a ported cylinder.
  7. you can use these pistons on a stock cylinder you just need to have them bored to .80 over this makes the 347 a 370cc. The only reason i took them ou t is because i had Jim (passionre) & passion racing engines do a full drag port on my bike and i could not run these pistons as they are relief cut from vito's to raise the exhaust port without porting the cylinder thes piston work great on a bike with a mild port job or even a bike with no port job as they make the motor react like it is ported. Check out vito's website for the exact specs.
  8. I have a set of .80 super stock pistons for a banshee they were only used 1 weekend and look great if interested make an offer they are like brand new there isn't even any scratches in the sides of the pistons.
  9. yes there is a stroked long rod crank it is harder to find a stock rod stroker crank then a long rod stroker or so i have found out almost every stroker i have found has been a long rod stroker. Check ebay there is usually a few of them on there.
  10. how much for everything? I am very interested and do you take paypal?
  11. check your float level find ou t what it is suppost to be and check it sounds like the float is a little high
  12. do the forks come with a drum? the forks will not work in a banshee drum.
  13. I need alky carbs thats it.
  14. you can use the above setup if you are not running any rear suspension. (bolting to grab bar and bearing carrier)
  15. I have the same question if you have a stock rear swingarm as i do i was thinking of mounting the bottom of the of the wheeliebar to the the mounts for the rear skidplate and fabricating a piece to weld to the top of the swingarm for the top rod of the wheelie bar to mount to this keeps everything on the swingarm.
  16. well my banshee only makes 300 foot passes so i am not worried about fuel economy but what about installing power jets? isn't that a must? I have like 3 power jets just laying around. Thanks everybody. I 'll let you know how it turns out.
  17. I am either going to run fasttrekkers or 4-snows depends on the track conditions the series I run mainly runs at fairs so the track conditions constantly change.
  18. I am running stock suspension witha 4 foot wheelie bar this year and i am wondering if there is something else i can do to amke the suspension work better. I also run the front end lowered. I need all the traction i can get as we cannot run ice screws in the tires anymore this year. Thanks
  19. to convert to alky "
  20. "
  21. honda bond that is what i used. just my .02 you can get it from a honda dealer
  22. how do you convert the carbs to alky i have 33mm pwk's
  23. I need a set of meth carbs i have a almost new set of keihin 33mm pwks i would trade or work out a deal with someone.
