silveradohd
Everything posted by silveradohd
  1. Sounds like slides are in backwards (carbs). Also, your jetting is too lean. 280 is to run with airbox. Should be around 310/320.
  2. Just buy some new a-arms, you will eventually get them anyway. The least you could do is buy some wheel spaers.
  3. Before you start buying, do some research on the company & it's parts. You will be surprised. Best thing to do is get a set of pipe's & go from there. So much to do.
  4. Have the same problem. Mine have graphics on them, so everytime I install them the handle bars come off. When tightening them down, start from the back. It is a lot easier. They are well worth the hassle.
  5. I would not worry. Rangers are not checking. If they do start, they will need a lot more rangers.
  6. How do I check if my ignition is OK. Right side spark plug wire is OK, but left side sparks every other kick.
  7. Your best bet is too find some graphics you like in a magazine, go to a graphics shop and have them copy on to vinyl graphic paper.
  8. I would skip the speedo, shock covers and case savers and get some used pipes. You will have to rejet, but you could get the pair of jets for under $10. Another option is to advance the timing. Although I am not sure if that can be done without pipes.
  9. You need a bigger hammer. A friend of mine, had the same problem (RUST). Good luck.
  10. I would check out the RIS chromoly swing arm, you will be surprised how much lighter it is than stock. Do not worry, they will take a beating.
  11. Trail tech lights from alba are same strength as stock, they just look a lot better. I use to have handlebar lzr lights, they broke when I rolled bike. For the price, I would go with the trail tech.
  12. Yes, I still have stock clutch. 3rd & 4th gear do engage, but it just revs. Ripped off head from the cylinder, dome o-ring is blown. Could this be my problem? Or should I look into the clutch more?
  13. Need help guys. Was in Glamis for last weekend and was having a problem with the shee. Bike runs great on 1st and 2nd gear, when I shift into 3rd bike just revs and does not go any faster. Checked throttle cable and it seems fine. Not sure what is going on.
