bansheeman95
bansheeman95's Achievements
  1. hey there, decide to put her back up for sale, still has been sitiing for a year, dont have time to ride with new baby. will also consider trades now. thanks Bryan new email [email protected] thanks
  2. found my original 95 seat cover, i took it off in 96 so it still looks new. 25 shipped. thanks bryan
  3. used for a year, went to 17`s 40 shipped. thanks Bryan
  4. Built by Sandtrax in Tulsa,OK Custom paint Powdercoated frame Sandtrax porting CPI inframe drag pipes RIS +6 swingarm Ricky Stator +2 chrome a-arms Works dual rate front shocks IMS double wide pegs with kickups 22x11x8-9 paddle haulers in rear 21x7x10 smoothies in front Kehein PWK 28mm carbs Dual K&N filters Pro Design manifold Cool Head w/17cc domes Sandtrax modified reeds Vitos Pistons Ricky Stator/PIAA duner lights Ricky Stator 200 watt stator Dyna FS ignition ***Too much to list*** Everything is polished or powdercoated Tons of billet parts 67hp/37 ft-lbs. One owner/Clean Title Over $18,000 invested make a reasonable offer Serious inquiries only. email for pictures Bryan Hollie [email protected] (918)850-4939 ebay link: http://cgi.ebay.com/ebaymotors/ws/eBayISAP...bayphotohosting
  5. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...bayphotohosting
  6. my mods are a stock welded crank, 28mm pwk carbs with K&N`s(I want to keep these for some low end unless the crank will make up for it if i go to a 33 or 35mm carb, Sandtrax MX style porting(which will work with the stroker crank) vitos pistons, stock modified reeds, CPI`s,cool head, 17cc domes, 225lb. compression. 111 octane race gas, makes 67hp 37ft lbs.
  7. does it add a noticible increase in torque? im at 67hp with the stock crank and I want to be around 80, do you think i can get there with just a crank change???
  8. I found a vitos kit on ebay for 500, doesnt wiseco make vitos cranks and pistons???
  9. where can i get one ? my mechanic wants 650 for them. any cheaper??
  10. I know antifreeze is green it just looks a lot greener than normal, like a dye was put it, it may just be the picture, plus ive always run the orange so i wasnt thinking about it being green anyway. some red dye would really make it look better though, it almost sticks out too much to me.
  11. shave the front fenders, if you like fenders you can get a graphics kit. newer pipes, those are the first FMF`s they made I think. I bet you could get more power out of newer set. but if thats all you got, run em. get rid of the clear hoses, is that green dye in there? at least switch to red dye. go to a 20" tire, i personally just dont like the balloon tire look. clutch insert, water pump cover, maybe a bilet kickstarter if money permits. same on the other side, a stator cover. or you could go for all performance mods. looks pretty good over all though.
