bronco91shee
Everything posted by bronco91shee
I have been slowly building up a home gym which now includes an exercise bike for cardio I do about 3 days a week and one day a week at the actual gym because of 2 kids. I do not own land to ride on, but plan to get out about every third weekend in the summer to local play area or MX track. So not super serious, but not couch potato either. New house will have land and I;ll be able to get back to riding multiple times a week.
What is the point of the smaller rear tires and wheels? What tire size would you recommend for front and rear as long as I'm looking at tires and wheels. I assume you want a shorter sidewall to keep the bulge down when cornering. And you want smaller diameter for gearing and so you can overpower them to spin when you need, but still hook up when you need? But this would lower the frame height and axle carrier clearance with the ground, which I assume should not be an issue? Also, what air pressure do you recommend? I was running about 10 in the front and about 8 outback trying to hook up on bald tires. SO new tires I would could go abit higher.
Last year I did my first MX race. This year I plan to do more as my free time and bank account allows, so nothing super competitive. However, I know the biggest reason I am slow right now is due to my body, not my quad. So I have been working out more based on what was sore after track days last fall. Just wondering for those of you that are more serious into racing, what is your workout schedule like and what weight machines/exercises/ stretches do you find most useful and how often?
Been riding for 20 years in Michigan and have loved my 20x10x8 turf tamers for normal trails, light mud, light sand. But now they are worn out. This summer was also my first time at my local MX track, loved it so much I joined my first race and will be back for more next summer. I am limited to about $500 in upgrades per season if I will have enough money to actually attend races and minor repairs. Racing only for fun, not chasing points or sponsors. I see most guys for years running ITP holeshots, so I assume thats a great option. But I also see alot of the newer quads stock with radial tires that hook up really well from what Ive ridden on. But i can get brand new turf famers for $75 which leaves me money to buy actual banshee nerf bars(currently using modified 250R to get by) and I need some front wheels cuz I bent those in practice as well as some new goggles and to replace the leaking intake mainifolds. Hence I need multiple things to get back on the track next summer, but I know rear tire quality is key. So what rear tire is the best for just fun at the track, still running stock suspension but a +4 stroker motor. Also, since I need new front wheels because my blue labels are bent and leaking, do I just upgrade to red labels? Or is that a waste of money and I should go straight to beadlocks?
Complete 1998 Banshee Part Out
bronco91shee replied to 19banshee98's topic in For Sale - Parts & Accessories
front shocks still up for grabs? text me at 847-239-0146 -
Are the 17" ones to fit stock aarms? If so whats the going price for those?
left side misfire and running hot
bronco91shee replied to bronco91shee's topic in Banshee Repairs and Mods
No idea how to do a leak down on a 2-stroke. -
Not sure what you mean by pressure test results. I have stopped running it now since it popped out with a new plug. First two times I questioned my install method of a used plug(crushed washer) on a new aluminum head. Thanks for helping -
engine-+4mm stroker, mild dune port, FAST head, stock carbs with twist throttle, +4 timing, K/N in box.Fatties. Last summer after stroker rebuild it was running great down a trail and just died. Found ground wire on stator broke off. New stator, and ever since the left side is issues. Runs 20F hotter at head and 40F hotter at exhaust port just idling. Misses alot at part throttle. it also has weak exhaust pulse on left side compared to right through out entire range. Runs great at WOT. Throughout about 10 hours of riding, adjusting, checking, replacing things it has blown the left spark plug out 3 times, good threads in head, new head. new plugs, does not matter. New V4 this weekened, no help. No intake leaks, no cross tube leaks. swapped plugs and wires left to right-no diff Swapped carbs left to right and the miss tends to go away, but still bogs in mid range like needle jet, changed that to all five positions and it did not help. swap carbs back and misfire is back on left side. Of course been through carbs several times. Checked float height and intake air screws, needles. Compression is 128psi left and 130psi right at sea level, which is the same it was after the rebuild so no worries there. Out of ideas. Any one else have some? Thanks in advance
Oil Injection Removal for a noob?
bronco91shee replied to ESC907's topic in Banshee Repairs and Mods
Way to be a jerk. Owned three blasters. they can be unreliable. ID of the hose leaves you screwed when debris happens to get in there or the pump has issues or other types of issues. Thats why I have three oil injection bottles in the trash over the years, to make sure the engine stayed safe.- 26 replies
- Oil Injection
- Remove
(and 1 more)
Tagged with:
Last time, I tried to adjust it per the book. Does anyone have a better way to do it? Does it change at all from stock build to all the parts i have added?
Thanks for all the good replies. I will also adjust the screw and move my shifter up. I already moved it up one tooth from stock for my boots, but I can try two teeth. My 4mm is still running stock carbs, so its deff not a race bike, but has more than enough power for everything I do, so I'm guessing a cut trans is not a necessity just yet, but is deff worth looking into.
What does a cut tranny do for me? Eccentric screw, you mean the one in the center of the clutch basket that pushes on the ball? Rider error part, Certainly can be an issue. would putting the stock shift shaft back in help fix this issue? I have tried pulling up on the shifter until it phsyically stops while riding, thinking make the modified shift shaft required a longer pull to engage the next gear. Thank you for your thoughts
Short story.... 97shee that wiped out a crank. Hotrod 4mm stroker+ ported cylinders to match with the basic rebuild. While I was in there I got the FAST Racing clutch pack/springs, modded shift star, modified shift shaft/spring, clutch perch, clutch cable, recommended trans oil, and other basics while in there. Set the clutch rod slightly outboard of the mark on the crankcase per FAST. I bought everything exactly how they told me, because I knew they had good experience on banshees and I wanted a one time quality build. Never had shift problems prior to rebuild. Now only if I let RPM's drop between the first three gears will it shift(basically the same way I used to shift with no clutch prior to rebuild). 5th and 6th it just will not do even rolling down backside of a dune with no load. With the engine off, it will run through the gears just fine as I roll it, so I know its not a shift fork or hard part. It really just feels like the clutch is staying engaged I found no concerns with the "clutch rod" that passes through the motor. No issues with the "pivot Rod" that attaches the cable to the "clutch rod" and no issues with the ball on the end of the "clutch rod". The basket had minor wear where the clutch plates ride, so that is the only clutch part I did not replace. Does anybody have any ideas if I did something wrong, missed something, need to "upgrade" another part to match the other "non-oem" parts I installed? I have been tinkering for a year with no ideas, and the guys at FAST are trying to help, but its just to the point where they need the bike to diagnose anymore than they already have, but they are several states away so that is not an option. Thanks for any input you all have
my brother is on the quadzilla site and has a hybrid. always giving me crap his 500 will whoop on my shee. (he usually dont beat me by much even though he works on it constatnly). well i guess a bunch of e2s.com guys as well as teh zilla guys are meeting up there the weekend before memorial weekend. the invitation/challenge has been put in my lap to compete with these guys...lol. my shee is fairly stock, so i know im gunna loose. im hopeing to round up sum shee's on here that can make a stand for us. i know i can beat a few, but some of these guys are real serious and i dont stand a chance......that and i just wanna see some sweet quads and races.......anybody care to join?
DG pipes and silencers are they good?
bronco91shee replied to 907banshee's topic in Jetting & Exhaust Forum
I have ridden banshees with fmf(mine, personally), pt mids, t5, dg and shearer. for ana all around pipe, or good woods pipe, imo is the fmf. i had dg first b/c of the price, and it was better than stock, but i just wasted the money, cuz i dumped them and bought fmf later. teh pt mids were very nice though as well. the t5 are my favorite for the dunes, but suck in the woods, you will wear out ur clutch hand trying to keep he revs up. i persoanlly sat on here for a few weeks and on ebay. i got my fmf for 200$ pipes and silencers....i cant imagine a better deal personally. keep your eye out, the economy sucks and i keep finding ppl hard up for cash.....sad, but at least to my advantage.... -
the thumb and twist throttle
bronco91shee replied to vegas banshee's topic in General Banshee Discussion
I SECOND THIS! i have had 3 quads and every one i switched to twist. thumb throttle wears me out in the first 20 mins. i have no idea how you guys do it! i have never had a twist put me in any danger, and yes i have crashed and stupid stuff over the years, but never b/c of that. and honestly, most days i would rather not ride with my freinds than borrow one of their extra quads witha thumb throttle. just my .02. and a side note, i can run through whoops for hours straight becasue it is a natural twist motion to keep going.... :cool: -
setting up some ice races for the winter
bronco91shee replied to bansheejoel's topic in Riding and Events Forum
yea. do we know how thick the ice is still? is it possible to go any time soon. i just got my quad outta of storage to get it ready...hopefully we can do it soon before the spring thaw. lol. that already happened around here though. -
Space saving storage of your Banshee
bronco91shee replied to speed-racer's topic in General Banshee Discussion
I DID THAT LAST WINTER MYSELF. THAT WAS B/C THE 3RD GARAGE WAS TO FULL. LOL. ANYWAYS. IT RAN WHEN I PULLED IT IN AND TEH CDI WAS DEAD WHEN I PULLED IT BACK OUT INTE SPRING. IDK WHAT HAPPENED. MABYE TO COLD? NEVER HAD THE PROBLEM BEFORE. AND I KNOW FOR A FACT, NO ONE ELSE TOUCHED THE QUAD OR THAT GARAGE FOR THOSE 4 MONTHS IN BETWEEN. BUT OVERALL. I AGREE. ITS A GREAT SPACE SAVER.... -
i think i have a set of stock front tires that i was gunna throw a way anyways. and my turf tamers have done their time. can i just stud both of those sets easy enough? i know there not fancy, and mabye not the perfect size. but free is free. lol. anybody tell me where to get studs and how to do it? also....im asssuming round here the ice dont freeze good till like january? so im guessin i have some time to get mine running good? -
those are the 2 big places i know as well. have been riding for 20 years as well. i grew up north of gr. now live in detroit. teh best suggestion i have is to go on the mi.gov website and look up the legal trails nad stuff. i dont beleive there is anything close to you. but i suppose you could check in.gov as well. i know the mounds are near by me, over here. and there are lots of trails in big rapids, where i lived for a bit-but not legal. its sad we dont have more legal places to ride. i guess i was lucky growin up in the coutry and riding the farmers fields and whatnot. but the legal choice is only one you can make. im not a fan of being illegal, and certainly against trespassing. but public land is fair game in my eyes. sorry i prolly didnt help, but those websites might give you insight. otherwise , i know my local stealership sells an actual book on all legal trails for all differnt activities. thats another route, if you didnt already know about it. also search preicate stuff. it seems the more i look, the more i find private tracks and land that will let you ride for a daily fee. best of luck
outdoor ice racing Should I use a 8" rear or 9"
bronco91shee replied to motodrumer58's topic in Flat Track/TT
i have no idea. but i have played on the ice before, and was thinking of gettin into racing this year. any ideas of what tires to run? does it matter as long as i can stud them, what design they even are? how many studs should i use in each? any help would be great, thanks -
i would be intrested if i could get some tires. i have 3 other ppl i think would come to ride as well. but none of them have studs. mabye we could make a studless class, just kinda more fun than a real race, for those who dont have the studded tires but still wanna give ice a try for the first time........dumb idea? either case, i would prolly stop out to at least watch if yall dont want regular tires out there. coming from detroit, but would be worth a drive. guiess i would have to get mine running soon.... pete, the wife said ur stateside sumtime round christmas?..........? -
How much interest is there
bronco91shee replied to bansheejoel's topic in General Banshee Discussion
i would be up for it for sure. i live in detroit now. but my parents live only about 20 mins from there. i did it a few years agow it some freinds. it was a blast. the only issue is how serious you guys will get, cuz i dont have studded tires and am not really intrested in buyin a set just to race once or twice a year. but other than that. im game. could prolly help plan if you wanted or needed. as to dajogejr.....if we planned it out, we could load ur quad in my bed and make a day trip outta it if you would like. im sure my 2 brothers would join as well, but they dont have banshee's.lol. keep the plans posted please or pm me if i can help at all
