bansheecaptain
Everything posted by bansheecaptain
  1. the crank is new still in the box ,never been used
  2. yea im paying 300 for jugs with stage 3 trinity port , wisco welded crank and all seal and pistons
  3. yea did some reading 33 sounds better to use . i ride alot on tight and open trail . plus 1-2 dune trips
  4. somy engine mods are +4 timing , 20cc domes on noss head , and gold series FMF pipes , vforce 2 reeds. and now soon too be a trinity stage 3 ported jugs . so my question is will dual 35 be too much , i plan on swapping my FMF pipes out for a trinity set of pipes or cpi's
  5. yea i got no port done to my jugs that are on there now
  6. right on , yea these are stock bore jugs with stage 3 port , trail/dune port
  7. ive looked at posts all day about trinity racing ports and how everyone says try passion or fast first . well heres my story my uncle has a set of new jugs with trinity stage 3 porting he never was able to put them on his banshee because he blew his writs out couple months after getting them so im getting these trinity ported jugs for dirt cheap and was wondering if it was worth it plus what kind of hp gains am i going to expect
  8. yea for sure dude . im heading to st anothney sand dunes this friday for 12 days so when i get back we will have to meet up some time
  9. thank SAVAGE420 , yea just a normal carb not a airstriker. i just remember the stock ones have a tube between the carbs so was just checking
  10. this winter im planing on stepping up on my engine to a +4 stroker and right now i have a single carb kit with a 35 could i keep that carb and buy another 35 and hook them up or do i have to by a pair that are ment to run dual carbs
  11. sorry the weisco race piston could be the same as there prolite not sure
  12. yea my mods are in my sig but , i have no port and stock stroke . im running fmf gold series pipes , and i run 94 octane . and i have noss head with 20cc domes . oh and still stock bore
  13. only problem i dont have a stock key and i would have to get one somewere , im at 1100 ft elev . and how would i tell if the timing is to much say 4 -5
  14. yea you will ripp those paddles right off , best tire going around this forum is the honda radial , i would try those first as they are going to be my next tire
  15. so long time ago before timing plates i put in a degree key im pretty sure it was only a +3 from alba but it might be a plus +4 , now my other thing is im running 20cc domes , now would it hurt if i got a timing plate and moved it up one degree so i might be at +4 or +5 , how can you tell if its to much timing and will detanate or not. sorry if this is a dumb question
  16. i use yamalube also great oil ive found .havent fouled a plug ever and 7 years and have only done one top end and everything looked good could have just put rings in and still ran with the same cast piston .
  17. i figured i would have to play with it there but just hoping to get some what of a starting point
  18. sorry though it was there , i have fmf gold series pipes , 2-1 35' carb set up , vforce 2 reeds , coll head with 20cc domes , +4 timing , wisco ported pistons , lightned flywheel , and no air box
  19. i got cool head with 20cc domes stock port but i have the wisco ported pistons , +4 timing , fmf gold series pipes and trinity 2-1 35' carb set up , lightend flywheel , and vforce2 reeds
  20. yea sorry i ment jump down , yes still got single 35 im running at 188 main
  21. well i have the skat trac 8 paddle right now , and it seems that i can spin those pretty easy not really hooking up , with my mods there in the sig would i be able to step it up to a 9 or just try re gearing , also i dont do much draging but alot of hill climbing and jumping
  22. hey right now i ride at 1000ft above see level and im heading here to st anthony dunes in a month and i heard the elevation is around 5000ft so question is how many steps up in jetting , like i have no idea if i sould go up 2 steps or 4 , just dont want to spend most my time playing around with jetting
  23. thanks man for the help .
  24. i tried running a search but couldnt find any , but I want to take off the switches off the bars and put two toggles mounted somewere else , so jst asking how i re wire the switches to toggles .. thanks for any info
