MRMOONEY
Everything posted by MRMOONEY
  1. YOU HAVE EMAIL!!!!!!!!!!!
  2. how much?
  3. i've got one, ill sell you for 100, and it comes already lightend
  4. ditto, i got the complete front breaks from a 89
  5. i was actually thinking around 95 or so, also i got a nos kit to put on it still should be over 100 horse no prob
  6. how about my bike guys? +4mm stroker full drag port 210 lbs compression alky power pro 410's 2-5 override timing advanced about 15 degress pvl igniton
  7. I RAN A COOLHEAD WITH 16CC DOMES AND HAD 195, LBS, MY NEW MOTOR HAS 24CC DOMES AND HAS 180LBS, GOING TO 18CC TO RAISE IT UP TO AROUND 220 OR SO
  8. i have a complet banshee igniton system (stock) for sell 2 4 posts down if he doesnt have what u need
  9. DONT REALLY WANA SEPRATE THE STUFF, WOULD RATHER SELL IT AL TOGETHER SORRY, THIS IS A VERY GOOD DEAL
  10. i have a +4mm alky banshee on the bottle esitmating around 110-115 horse on the bottle. Mp racing did the work, also has 8 plate clutch pvl igniton and power pro drag pipes, should get the job done hopefully
  11. I have for sell a from an 89 Banshee complete igniton system, you get coil, cdi wirinig harness, Key switch On/off switch, regulator, fly wheel (lightened or stock) stator, 350 obo for everything,
  12. ive also got a set, mine are 20x10x10 on douglas wheels, used about 5 rides, in great shape
  13. i got one, ill sell it to ya for 25 bucks
  14. YEAH MY NEW +10 MP ARM IS 4 LBS LIGHTER THEN MY OLD +6 LONESTAR ARM CRAZY STUFF HUH
  15. i run the stock ones that are ported but dont run tdr's i run boyseen dual stage, i have had v force also i noticed alot more on top with the stock ported cages
  16. i can get you some custom cut domes also, let me know if you need something, i run a long rod +4mm stroker motor without a plate looks alot better in my oppion
  17. ILL GIVE YOU 100 FOR THE HEAD WITHOUT DOMES?
  18. ive got a duel petcock tank, pm me
  19. what else do you need?
  20. try this... hope this helps http://www.planetsand.com/ubbthreads/showf...sb=5&o=&fpart=1
  21. yes but who's the inverntor? they had to get it from someone also right? i bet alot of builders have copied others work.
  22. I GOT SPINDLES, SOME 36MM MIKUNIS, AND BREAK PEDAL AND SPRING, PM ME THE 36MM CARBS I GOT THE INTAKES AND K&N CLAMP ONS FOR ALSO THE CABLE.
  23. ALSO VETO'S IS SPELLED VITO'S. DUDE THE WET KIT IS BETTER. NO PORTING NO CARBS= STOCK BIKE.
  24. I HAVE A SET OF ALKY CARBS FOR SELL, YOU WILL NEED TO GET BIGGER CARBS, THE STOCK CARB FLOAT BOWLS ARE TOO SMALL, YOU WILL DRAIN THE BOWLS WAY TO FAST, YOU NEED TO GET A PINGEL FUEL PETCOCK, OR A FUEL PUMP. ALKY LOVES COMRESSION A GOOD ALKY MOTOR SHOULD HAVE AROUND 190-210 FOR COMRESSION. ALKY ALSO LOVES TIMING, I RUN MINE ADVANCED 12 DEGRES. YOU ALSO MIX IT A LITTLE DIFFERNTLY, AND SOME PEOPLE USE DIFFERNT PLUGS, I DONT BUT SOME DO. I HAVE SOME 36MM MIKUNIS THAT ARE SET UP FOR ALKY FOR SELL PM ILL GIVE YOU ALL THE INFO YOU NEED
