deli sandwich
    NJ
  • Interests
    off road internal combustion self propelled vehicles
deli sandwich's Achievements
  1. Well I'm thinking of selling or parting out my 2000 banshee because i don't feel like or have the time to work on it anymore and wanted to know what you guys think i could get for it. Engine 421 powervalved cheetah cylinders mx port / 4mm long rod hotrods crank trued and welded / 35mm pwk carbs / aluminum airbox / uni filters / V-Force reed cages / cut transmission (not over ride) / alba shift drum / rz shift forks / hison clutch basket / barnett clutch / hydraulic clutch with stainless line / terry cable throttle / dyna CDI ignition / NOLOGY coil / ricky stator / 68mm wiesco prolites (blaster) / pingel fuel petcock / toomey radiator / alba clear coolant lines / prodesign impeller. Chassis lonestar 2+1 a-arms / lonestar -1 swingarm / lonestar axle carrier / lonestar +4 axle / lonestar locking rear hubs / lonestar brake hub / wave rotor / hiper tech carbon fiber wheels 10x10 dual beadlocks / holeshot xcrs all around / elka elite rear shock dual rate, remote resevoir / lonestar tierods probably some other bits and pieces that i can't remember right now......
  2. is this still for sale?
  3. this is kind of overkill, but if you put in an RZ transmission 1st, 2nd, and 3rd are spaced farther apart and 4th, 5th, and 6th are closer together.
  4. these bugs that are anywhere from an inch to like a foot long that have like 10000 legs and run at mach 7 across my floor and creep the shit out of me. i have no idea what they are but i hate them
  5. how big is the gap between the gear and the oil seal? the gear doesn't sit flush with the seal, there is a little gap between the gear and the case, but not much.
  6. you should be able to just pop it out with a flathead screwdriver, i don't know anything about a copper ring, mine doesn't have one
  7. yeah, -1 lonestar
  8. havn't been around here in a looong time.........anyway, i have the 421 and it pulls like a freight train, power everywhere. Im having electrical problems right now (right cylinder not firing) but besides that its completley reliable. Even only running on one cylinder its still as fast as a blaster . If your looking for a comparison, my friend had a YFZ piped, K&N, and cam and i beat him like he wasn't moving.
  9. i had a UM for the swingarm but completley destroyed it in the woods, it bent so much from a rock that it forced my chain to come off which then tore up my brand new lonestar swingarm and carrier i have a PRM now, MUCH better
  10. fashnickered fugged up
  11. i have one of those in white and red
  12. sorry, carbs are gone
  13. sorry, i don't have the pivot bolt and the hubs are gone
  14. new never used 33mm pwk keihin carbs w/ throttle cable $150 +shipping
  15. its still 100% stock, no boring or porting, just needs to be honed. I sold the right cylinder a few months back
