99Red_Roostr
Everything posted by 99Red_Roostr
  1. yeah but it cost $3-4kmore than a Banshee - so add $3-4K TO THE sHEE AND $0 TO THE cow AND SEE WHAT HAPPENS. 99RR
  2. Kill switch 99rr
  3. how do I get my icon back? ( (( ((( (((( ((((( ((((((rtsooR_deR99)--------->>
  4. In front you will get nasty wrist slap , there is no replacement for +2 A-Arms. In rear it depernds how you ride, it you get crazy (thats what there for u no)- you will bend an axel
  5. terather kill switch - so when you fall of (and you will) you don't wreck your Shee more than nessecary. 99red_roostr
  6. I live in Minnesota -20 yep!, Jet rich & get Paddle Master tires for the rears, stay on semi hard pack cause if it gets deep enough to bottom out the frame your done!! BUT IT IS WAY FUN!! I hate snowblowers you don't shift, there boring!! ( (( ((( (((( ((((( ((((((rstooR_deR99)------>>>>>>> *************************************************************
  7. Teather kill switch - when you fall off it stops!! #1 mod for any machine & only ~ $20.00 ( (( ((( (((( ((((( ((((((rtsooR_deR99)---->
  8. I thought I was rich after a rebuild and some mods (vetos SS) , but after finally getting through a long break in and finding a few bugs ( needles not same on both sides) . Turns out I was leanall along ( but not for very long, or ridden hard ). I think it takes a while to burn off the oil from the rebuild before getting good readings on the plugs. Leave it rich till quite a few tank fulls, then start to dial it in a little at a time. 2c 99rr
  9. I was just makin fun - not serious! sorry if it offended 99rr
  10. I say it a HE-SHE or a SHE-HE ; icky either way 99rr
  11. I repaked em then test ride: On asphault - PaRT way into 1st gear crusing, then nail it, where it used to pull a power wheelie, it now burns rubber - its better hahaha thanks guys. 99rr :twisted:
  12. I currently run a medium/high modified 99Banshee. FMF fattys/w /Pc2 silencers with No-Packing. What effect do you think it has in performance vs packing??? Sound does not matter! 1) More power 2) Less power 3) No difference and what do you thinkI should change if I add packing? 1) jetting 2) needle position 2) air screw 3) nothing 99Red_Roostr - Dula foam pod filters/velocity tubes/34mmpj Keihins/ProDesign manifold/Vitos SS pistons/Cool head 18cc 185psi/FMF fatty pipes w PC2 silencers. 110 Gas 32:1 Klotz. Runs nice!!
  13. Do you ride a 250R or a Banshee ? 99rr
  14. Who would have a STOCK Banshee ??? and why?? 99rr
  15. I run +2 a-arms - hesitated to cut em - finaly did - love it. 2% of time would klike to have em back (maybe). 99rr
  16. The uncle will win! you and cousin will over-rev in excitement !! 99rr
  17. 51, but 25 when on the Shee! 99rr
  18. Crazy crazy - they don't like foam cause they clog up !! Well then were does the dirt go ?? - when you use the K&N ?? - it gets sucked in (_!_) Foam all the way if its dusty 99Red_Roostr
  19. If you want max traction - Paddel Masters - & very very tough , can run in gravel also. 99Red_Roostr
