badlarry
badlarry's Achievements
check for a bad reed , cracked or deformed and not sealing. My buddies banshee had a broken reed and it would run fine under no load. but when you started to get into the powerband. it fell on its face and sputtered. turned out to be a cracked reed.
O.K. I have the tdr carbon reeds in my banshee. I also had them do a reed cage mod. which is a knofe edge on the inside of the reed block and opening up the stock reed block. I also do not run the stock reed stops. has been running hard for a while now. tdr built my motor. I am happy with it. it is a stock stroke mild ported banshee with 4 degree timing advance, 20cc domes in the head, toomey t-5's. tdr reeds with cage mod. bike runs super. run them and dont look back
And with that box of ammunition there too! Lol just messin around but seriously move those fuel jugs before there is one less member on here!!
Vitos Superstock or Wiseco Pro Lite?
badlarry replied to esseclipse's topic in Banshee Repairs and Mods
O.K. I had a brand new motor once.............. New trued and welded hot rods crank ( stock stroke) I got the stock head cut a little, and had the builder install vito's super stocks. bike ran pretty good jetted with 330 mains, and vito's needles ( pretty rich?? so I thought??) the machine had stock carbs with no air box lid with K&N with adapter plate and pre-charger. well it burned up the right side piston. Burned a hole the size of a quarter right through the middle. I can't say what caused it?? I figured it was the super stocks because that was the only black magic going on in that motor. Upon rebuild I went with a .020 over set of wiseco pro-lites, new vitos hemi head with 21 or 20 cc domes??? cannot remember that far back. bought new rubber manifolds from upp as well as new rubber boots connecting the airbox just in case there was a crack that I did'nt see and was'nt leaving anything to chance. I also rejetted with 310 mains and re-installed my toomey needles on the 4.5 clip ( 4th with shim) and ditched the vito's needles, bike ripped. It puked coolant and I got a hot plug reading so i went down to br9es in place of the br8es and it has been stellar. No issues of overheating, machine now has 19cc domes running on 50/50 mix of 110 and 93 with 40:1 benol ( smells like circus peanuts..... awesome!!.) It now has probably 80 -100 hours on it. may need a rebuild soon but for now still going strong, ( compression started at 158 psi, now only getting 135ish?? guage may be f'ed up too it is older than dirt and bike was cold and had'nt been run in a few days.) I'd go Wiseco Sorry for the Loooooong story. Long day and I just was outside looking for the dog wink wink -
Nevermind, I'm clearly an idiot! NOW I see that you had mentioned the t-3 pipes. those can be worth something. I had a set of t-4's that ripped. I traded up for a set of t-5's but the t-4's were good too!!! so you maybe want to part it oyt. fun for you and you will prob get more $$
Hey, Also, that quad is not bone stock. Those are not stock pipes. I can't see the silencers but the pipes are def not stock! but I'd clean and fix what u can as cheap as you can and then try to trade it. You'll find someone who wants to go fast!
So here is my results, but maybe I was unlucky or a touch lean. I had a set of bare toomey t-5's ceramic coated by jet-Hot. They look killer still except the bottom12 inches from the cylinder. they are flaking and look like shit. so I'm gonna wrap them in heat tape where they look shady.
artrax tires. I have a set of the artrax 20 x 11 x 9 I got from motosport. They seem to wear o.k. I got 1 flat from a nail and it was plugged in 5 min and has not given me a prob. Banshees rip tires period. nothing is really gonna last that long if you ride rr tracks or pavement but for 49.99 I'm gonna buy a second set real soon. Right now they go back and forth from the yfz to the banshee. **1 thing is Moto-sport shipped these tires like complete fucking idiots. they were banded around the circumference crushing the tread and made the tires a fuck show to mount. They were all bent up like pretzels. I finally used luck on 1 and a bead cheater then starting fluid on the other after a long wrestling match trying to seat the beads. i will use starting fluid in the future for all my quad tires. It is the easiest way but can be dangerous
you can try an easy out. But I would get a few new drill bit and first drill a small piolt hole then follow up with a Left handed drill and just creep the drill. it will bind in the bolt and back it out. this is all after a good soaking in liquid wrench or some kind of lube/penetrant. works very well.
Well the Banshee tangled with a polaris razor and lost. broke upper J-arm. they were from "quad central" way back in 2000. they were manufactured by JD performance I think. They are standard width and +1" forward. I need to replace at least 1 upper. does anyone know where I can buy standard width +1 forward J arm to replace it??
I would also check the clutch. get it out on some grippy terrain or pavement and go through the gears. If the clutch is slipping you'll know on pavement easiest. my 2 cents
your plugs look exactly like mine. I hope someone chimes in and says they are perf. I thiink they r a touch lean? i also use 110 with klotz 40:1 but i only have 158 psi so I run 50 / 50 93 and 110. Benol. smells like circus peanuts
I'm pretty sure you wont find any other chain on any real high horespower machines besides regina. I've talked to numerous people who buy chains frequently, and as far as durability and not stretching it is only 1....REGINA CHAIN!!
Hey guys, I have a question about my jetting. The quad rips fine, no real bog. a slight bog or sputter before the power band if you load it up before she kicks. But my issue is this........ while decellerating, the bike barely idles. no ting ting ting ting ting, just quiet unless i pull slack out of throttle with my thump, just enough to have no slack. I am worried if I let people ride it who dont blip the throttle upon decelleration its gonna burn down. should i try a bigger set of piolts or richening up the needle a clip position or two. I am guessing pilot. it has 27.5 in it now. I want to not worry when someone takes it 4 a ride. bike has : .020 over bore w/ pro-lites stock carbs with air box and NO lid w/ k&n mild porting ported reed cages with tdr carbon fiber reeds vitos head w/ 20cc domes 158 psi t-5's 4 degree timing advance 50 /50 110 and 93 octane 300 main 27.5 pilot toomey needles on 3rd or 4th from leanest I hear a ton of videos and all these bikes fire while decelleratong, not mine, wtf???
