All Activity
This stream auto-updates
  1. Past hour
  2. This has symptoms of a bad CDI. Swap with a known working one and see if the problem persists.
  3. Green has never shown his face at LOTO even though he's supposed to be moving there.
  4. Wonder if he ever bought anything.
  5. Fucking WCJ.. Haha. Dude got so embarrassed about now showing up the the BansheeHQ ride that year he bounced.
  6. Today
  7. Hey What’s Up HQ’ers! I have a returning customer with a 98’ Banshee with a completely stock engine that I have worked on in the past. He brought it to me yesterday saying it has a problem with extreme loss of power and shuts off after about an hour of riding. He said if he lets it sit and cool down for about 25 to 30 minutes then restarts it to ride it again the problem comes back about the same time frame. So this is where I come in. I looked it over and I took it for a test ride. It did it to me just ripping it up and down my stone driveway. In no way it’s overheating. I removed the keihin carbs and checked them over and they were clean of any signs of contamination. He runs VP C9 for fuel and Klotz Super Techniplate at 32:1. I checked the reed and they were good. I switched all the electrical components from a known good running Banshee and nothing changed. The clutch is working properly. The front and rear brakes are working properly nothing hanging up. I did a compression test both cold and at operating temperature. Cylinders at cold was 110 and cylinders at operating temp was 115. Did a leak down test and it sat at 6 psi over night with no pressure loss. No engine noises present. The Banshee runs and rides normally. Now this morning I brought it out and started it up and let it warm up for about 4-5 minutes. Took it out for a rip nearby my house and I got it nice and hot the it did it. Now I noticed with the engine hot it feels like it’s got a ton of compression. So I got it restarted and limped it back to my house and it still feels like it has a ton of compression. I removed the spark plugs and nothing changed. So I drained all the coolant out of the system and removed the cylinder head and cylinders. Pistons and cylinder bores seems to be okay with just a slight sign of normal wear. Probably could just get away with new wrist pin bearings and rings on the pistons if needed. But that plan got blown out the window. When I went to check the crank. That’s where I found the problem. The lower rod bearings feel really crunchy with a small amount of side to side play with more being on the right side. Then when spinning the crank it self the main bearings also have a small amount of crunchy feeling and a small amount drag. I think he was lucky to catch this before it turned into something very catastrophic. So I’m going to be giving him an update on my findings today to find out what direction he wants to do moving forward with rebuilding it. I’ll be back with an updated soon. Thanks
  8. Yesterday
  9. [emoji897] [emoji897] [emoji897] Sent from my iPhone using Tapatalk
  10. [emoji897] [emoji897] [emoji897] Sent from my iPhone using Tapatalk
  11. Last week
  12. Crank is done! $$$$ 2BKING 🤑
  13. Earlier
  14. We did get the cylinders in Mar., but nothing can be done until we get the rods changed out on the crank. We took the crank to Crank Works for rebuild & rod length change in May. We'll see how long it takes. When we get the crank back, we can start on the porting & mock-up. Then have domes cut & get cylinders out for plating. It would be nice to have this all done before the end of Sept. but that's wishful thinking! 2BKING 👽
  15. La sección de curling en vivo de https://jugabet.cl/curling/live/1 permite seguir partidos con actualizaciones en tiempo real, resultados y detalles de cada ronda. Los aficionados pueden observar el desarrollo estratégico de cada encuentro y mantenerse informados durante toda la competición. La plataforma es sencilla de usar, funciona bien en móvil y ordenador, y ofrece una forma práctica de seguir este deporte con precisión y detalle.
  16. Matching sand tires and wheels. Kenda Dominators (22x11.00-10 rear) and I ITP Sand Stars (AT22x8-10" front) on Douglas Wheels https://imgur.com/a/GHKzKD4
  17. For sale is my 2001 Banshee that I’ve owned since new. Lightly ridden off and on for about 10 years — low estimated total chassis hours. Always well maintained. Key Build Specs: Patriot Racing 75HP dune port by Dan Bottom end balanced by Dan at Patriot in 2002 Top end freshly machined by Lake's Motorsports with .020 over 64.5mm Wiseco forged pistons – Maybe ridden 10 hours since then Coolhead with NOS/Pro Design-style domes Dyna FS programmable CDI Toomey T5 pipes, recently repacked silencers. 28mm Keihin PWK carbs with plenty of jets. Well tuned for here. Magura hydraulic clutch Lock-up clutch with adjustable arms Brembo front brake Full long travel suspension: Long Travel A-arms, DuraBlue +6" rear axle, Elka Stage 5 front & rear shocks (full compression & rebound adjustable), Elka System 5 steering damper Extended steering stem with damped bars. New tires: Front 23x7-10, Rear 22x12-9 SunF aggressive tires with DWT rim covers DG race pegs & nerf bars, DG six-pack rear rack, DG front bumper New 5.1 gallon plastic tank Floated stator, Trail Tech regulator/rectifier, bright LED lighting Billet clutch cover + billet stator cover Extras Included: Full spare sand tire/wheel set: Kenda Dominator 22x11-10 rears + ITP Sand Star 22x8-10 fronts on Douglas wheels (excellent condition) Complete Nitrogen cylinder + regulator + stainless steel hose for charging the Elkas. Original blue plastics with wear and sticker (solid and straight, easy to refresh). Everything else on the bike is sorted and performance-focused. This is a complete, turn-key 70HP dune rocket that runs well. Strong first-crank starts, crisp power delivery, and planted handling in the sand. Located in Las Cruces, NM. Local pickup preferred with cash/test ride. Serious out-of-state buyers welcome with deposit and video verification. Shipping available at buyer’s cost. Asking $13,500 OBO Serious inquiries only. Feel free to message with any questions. Coldstart from two different angles.
  18. Delivery *** pouches Sent from my iPhone using Tapatalk
  19. I fill Amazon boxes and deliver pouches with cat/dog shit and or old meat/grease and leave them out…only took couple months before people stopped taking them. Sent from my iPhone using Tapatalk
  20. So earlier last week I helped a friend out with his diesel pickup. He let his wife drive the truck to and from her work. So my friend forgot that the truck was low on fuel. He told her to stop on her way home from work and put some diesel in it. So she wound up putting $60 of gasoline in it. Here is Nj you pump your own diesel but gas is full service. So we over the holiday weekend we dropped the fuel tank and flush the fuel system out and installed a new fuel filter. We ended up with 30 gallons of contaminated diesel/gasoline mixed. Now to catch a fuel thief part. My neighbors 18yo son bought a 2020 Chevy 2500 HD with the Duramax at the beginning of May. So yesterday he came over and wanted to know if I could show him how to service his truck. Oil change, fuel filter and a new air filter. While I was showing him I happen to notice he was eye balling the 6- 5 gallon yellow diesel fuel cans sitting outside of my garage. So we get done servicing his truck and I told him that he needed fuel and that he should never let the fuel level get below 1/4 of a tank because then you start sucking up the water and other garbage on the bottom of the tank that’s not good for the fuel system. Now speed things up. This morning I come out of my house to go to my garage to get my e-trike out to go to work and noticed that the yellow diesel cans were moved in a different direction. So I checked my rear door ring camera and lo and behold the neighbors son and 2 of his friends came over at around 4:30am and carried the fuel cans away and then about 30 minutes later they came back and put the fuel cans back. So all I did was put my hand on my head and then SMH. I then leave for work at 6:30am and get down the street and at the 4 way stop I looked both ways and noticed the neighbors son’s truck sitting on the side of the road with it’s hazard lights on. I ride up and asked him what happened (not telling him that I knew what he did) he said he was on his way to school and that turned the corner and the truck started to make a funny noise and then shut off. A couple minutes later his dad shows up asking him what wrong and his son says he doesn’t know. So I pulled his dad off to side and then told him I know what happened and then I showed him exactly what happened. His dad got pissed off at his son. So earlier this evening my neighbor and his son came over and the son apologized to me for stealing the contents from the 6 yellow fuel cans. I offered to help them fix the truck but they refused and they said they had the truck towed to the dealership to get fixed and his son was responsible for getting it repaired.
  21. Thanks. I have verified all those things. 195 psi on each cylinder, .040 squish on each side and the motor easily passes leakdown. Just wanted to make sure I wasn't missing something.
  22. I have heard that the transmission oil in the right side can help keep that side cooler. If you have verified there are no air leaks, compression, squish, etc is the same, just run it.
  23. You are correct, sorry for the confusion. The left cylinder is leaner. Left carb power jet is 1 turn from completely open while the right carb power jet is closed. With this setting, the plugs look similar.
  24. Your information is off. You say that right cylinder is lean but you have to close the PJ completely, while the left is open. Can you clarify this? Sounds like the left is lean and the right is not.
  25. [emoji106] Finishing the build now, mounted a lightened but can swap to stock… Thnx Sent from my iPhone using Tapatalk
  26. TM 38 bored to 41mm. I swapped the carbs from one side to the other and the condition was unchanged.
  1. Load more activity
