What Is Jetting - A Great How-to Article. Communicating with your machine.
#1
Posted 29 February 2004 - 04:49 PM
What is Jetting
Carburetor jetting can be easily understood if we understand the basic principles of carburetor and engine operation. A carburetor mixes fuel with air before it goes into the engine. When the mixture is correct the engine runs well. The bottom line is a carburetor must be adjusted to deliver fuel and air to the engine at a precise ratio. This precise ratio can be affected by a number of outside and inside influences. If you are aware of these influences you can re-jet your carburetor to compensate for the changes. I'm going to show you some examples of how you can change your jetting for better performance and in some cases increase engine life. As with any engine work be sure you have good tools the correct parts and a good manual before you get your hands dirty!
Altitude Compensation
For our first example let's say we find a new riding area WAY up in the mountains. Our jetting is dialed in for our usual riding area which ranges from sea level to 1500 feet. Our NEW riding area starts at 4000 feet and goes up from there. Going to a higher elevation will require will require a jetting change but which way? Like our fuel density, air density can also change. Higher elevations have less air density then lower ones. At high elevations our engines are getting less air, so they need less fuel to maintain the proper air/fuel ratio. Generally you would go down one main jet size for every 1750 to 2000 feet of elevation you go up (info for Mikuni carbs). If you normally run a 160 main jet at sea level you would drop down to a 140 at 4000 feet. Something else goes down as you go up in elevation is horsepower. You can figure on losing about 3% or your power for every 1000 feet you go up. At 4000 feet your power will be down about 12%-even though you rejetted! For our second example, let's say we are still at our new 4000-feet elevation riding area and a storm comes in. We head back to camp and ride it out overnight. The next day there's a foot of snow on the ground the skies are clear and it's COLD! Aside from getting the campfire going and making some coffee you should be thinking about jetting again! Cold air is dense air and dense air requires bigger jets. If the 140 jet ran good the day before you will need a bigger jet to run properly today. If the temperature is 50 degrees colder than it was the day before you can actually go back to your sea level jetting, a 160 main jet! If you don't rejet you can kiss your assets goodbye when you rebuild the seized engine. Air temperature makes that much difference!
Our final example will deal with something often overlooked. We are still up in the hills enjoying our NEW riding area when we notice the old fuel supply getting shorter. No biggie; there's a little store/gas station just down the road. A short trip a few bucks change hands and we are ready to go again. Out on the trail the bikes are running funny, sometimes "pinging" and running HOT. What happened?! When we changed jets to compensate for altitude and temperature we were still using SEA LEVEL gasoline. Gasoline sold at higher elevations have a different blend of additives to compensate for the altitude. Generally high elevation gasoline is less dense to compensate for less available air going into the engine and to aid starting. The lighter specific gravity of the high elevation fuel actually "leaned out" our mixture! One to two sizes bigger main jet will get us back into the hunt. If you ride in vastly different areas try to bring enough or your normal fuel along to last the entire ride. It will save you hassles and gray hair in the long run!
Pilots, Needles & Mains
So far we have only talked about main jet changes to compensate for altitude, temperature and fuel density. As most of you know there is a pile of jets in a carburetor. While main jets are the most critical for ensuring full power operation and engine longevity, the other jets are equally as important for a good running engine. Let's run through them quickly.
Pilot Jets: Pilot jets control the low-speed and idle mixtures. Many times an adjustable jet is used in conjunction with the pilot jet. The adjustable jet allows a precise setting of the idle mixture. If the adjustable jet is located to the rear of the carburetor and usually on one side it is a AIR adjustment. It controls the amount of air that mixes with the fuel coming from the pilot jet. If the adjustable jet is to the front of the carburetor, on the side or bottom, it controls the amount of air/fuel mixture going into the engine. In either case if adjusting the mixture screw won't improve the low-end running speed it's time for a different pilot jet.
Slide: Throttle valves (the slide) control the off idle, to one-quarter open, mixture. Some aftermarket carbs have replacement slides available with different "cutaways". Changing the cutaway changes the mixture. More cutaway is lean, less cutaway is rich. Some carbs do not have different slides available, so you have to compensate by changing the mixture on the idle circuit or needle circuit. Partial throttle hesitation or rough running can be caused by the slide cutaway.
Needle Jets: Needle jets control the amount of fuel going by the needle and into the engine at low to mid throttle. There are 2 types of needle jets used in a carburetor. One is a primary type that has a very precise hole hole drilled through the middle of it, along it's length. The size of the hole relative to the size of the needle determines how much fuel goes into the engine. The other type of needle jet is constructed essentially the same except for a bunch of holes drilled into the side of the jet. These holes allow air to mix with the fuel before it's metered into the engine. Either type of needle jet works well in most cases but there is power to be gained on high performance four-strokes by going to the needle with the holes in the side. These are called "bleed" type needle jets and produce more midrange power in a four-stroke. In any engine going to a leaner (smaller) needle jet is the easiest way to rejet the midrange running when going to higher elevations. Changing the needle jet leans out the mixture evenly at all the midrange throttle settings moving the needle clip doesn't.
Needle: Jet needles more commonly know as the "needle" control the fuel mixture throughout the midrange. The shape or taper of the needle dictates how much fuel goes into the engine at a given throttle opening. The needle must work in conjunction with the fueling requirements of the engine relative to slide position. If you have an engine with a strong hit in the midrange the needle will probable have a noticeable reduction in size the the slide is half open. Remember it takes fuel to make power and when the engine makes power it needs fuel NOW! If it doesn't get the right amount of fuel it pings or misses. You many have cleared up a little midrange pinging by moving the needle up a notch but at the same time you may have over richened some other areas. If the problem isn't too bad you won't even notice the rich condition. If the machine stutters before it comes on the power that part of the needle's taper is too small and the only way to cure it is to get a needle with a different taper. Finding the right needle can be difficult so hopefully moving the clip will do the job.
Main Jet: Finally the good old main jet comes into play at three-quarters open to full throttle conditions. Most of you already know a bigger main jet has a bigger hole so it lets more gas into the engine! Pretty simple! As simple as it is the minuet is absolutely CRITICAL to high-speed engine operation. Not only does it meter the gas into the engine, it can aid in cooling the engine as well. A properly sized main jet will let the engine make good power for a long time. One size smaller main jet may make greater power for awhile. A slightly rich mixture burns cooler than a lean one so be sure the main jet is big enough!
One final note on jets. All of them and the carburetion functions then perform tend to overlap into some other jet's territory. If you mess with one jet, you may have to mess with a few of the others. My best advice is to not change more than one jet at a time. Slowly work out the correct jetting and keep notes on what you are doing. If you get totally fouled up at least you can go back to where you started.
Sign, Symptoms & Causes
How would you know if there was something wrong with your jetting? If you listen, your engine will tell you! All you need is an interpreter. Since I speak and understand several different engine dialects, I will give you a hand. Let's start with lean conditions because they can cause the most damage. In a lean condition the engine will surge and sometimes ping under acceleration. The engine will also be "cold-blooded" (hard to start and keep running) but will run better when hot. The spark plug will look bone white or burned in extreme cases. The engine may spit back or sneeze through the carburetor once in awhile too.. If the engine is running rich the throttle response will be fuzzy and not too quick. The engine will burble, miss and blow black smoke. It will start easy but will run funny when fully warmed up. The plug will be dark, wet or fouled (possible all three!).
Ok so what do you do first to cure the problem? The very first thing is to check and adjust the float level. If it's off one way or another it can throw the jetting off too. Set the float to the specs and retest the running. The next item is to determine a rich or lean condition. Let's say the engine gets hot and doesn't pull well. This is a lean condition so the engine wants more fuel. Stick in at least a two size bigger main jet and try it again. If it's better but still not right go even bigger on the jet. and try it again. Bear in mind that drastic or sudden changes in jetting usually mean an air leak has developed somewhere in the engine. Find it and FIX IT! When the engine burbles on the top end come down one jet size at a time until it winds all the way down. Don't drop and more sizes! If the engine seems sluggish and lumpy or want to load up on the bottom end the mixture is TOO RICH. Adjusting the low speed mixture screw helps a little but doesn't cure the problem completely. What you need now is a new pilot jet. Go one size smaller and try the adjustment again. When the engine runs smooth with the adjustment screw about one and a half turns out from the seat you have it!
Final Thought
There's a lot more to jetting than just stuffing jets in holes and hoping the problem goes away. If you can understand what your engine is trying to tell you when it runs funny you will have a better chance or correcting the problem than someone who doesn't have a clue. When you rejet, go slowly and carefully until the problem is solved. As a final thought let me remind you that jetting is a lot like life, if you have a choice it's always better to be a little rich!
Now go to Reading Spark Plugs to finish off your jetting.
Credits: Article info from December '96 issue of Dirt Wheels, and editing by 4Strokes.com.
#2
Posted 01 March 2004 - 12:14 PM
I rode at the Shasta Dam OHV park this weekend. I'm jetted for 500' elev. 40-60 deg. It was about 40 degrees out and the park staging ares is at 1000'. I took a one fire trail that took me up to I'd estimate 3500', it was also faily cold out like 40 deg so that probably compensated for the elev a bit. It was down on power just slightly and didn't go into the band quite as quickly or as strong, but didn't bog. I pulled out a plug just to see what it looked like at 3500' and it was definitly darker than what it looks like when I ride at home (500') but still within what looked like an acceptable operating range and not in danger of fouling. I had installed a new set of plugs just prior to this ride. I went all up hill for about 15 miles at an average of 40mhp. I putted the last 1/4 to 1/2 mile to let it cool off a bit but that wasn't quite enough and when I stopped I got a little whiff of radiator fuid and saw a bit of steam. It must have puked a small amount out of the overflow or cap so I immediately fired it back up and went downhill for 200 yards, then it was fine. It's hard to say if the heat was from running rich or going all up hill or both. The 20cc domes probably helped it run better in the high elevation. I wonder how much elevation you can go up before it starts to bogg?
2004 Ltd YFZ450, Yosh slip-on, lid off, sand stars on ITP T-9's
#3
Posted 01 March 2004 - 07:44 PM
This was before I knew anything about jetting for elevation and temp changes...
All I had was an LRD p/s and no air box lid performance wise, I did notice it was at a lose of power, but the plugs where fine and did great the for the whole 2 weeks, of almost all day riding..
At times we where up to 11,000 ft and the temp droped about 15 degrees and it still ran ok....
Lots of fun!
96 Banshee: PT Mids, AC Bumper, LSR+4 Axle, Leager +2+1 A Arms, Works Tripple Rate fronts /w Finned resssies, Janssen -2.5 RoundHouse, RPM Tapered Bearring Carrier, 18" klaws on 8" itp beadlocks, mx razr's on .190's, AC ProPegs, ProDesign head w/ 20cc domes, ss lines front/rear, Pbrake b/o, F.A.S.T. clutch, +4 timing, TORS Removed, 400 ex throttle.
2oo1 Blaster: LT Susp, built motor, highly modded. Sold
05 CRF450R: White Bro's slip on, Twin Air filter, Traded.
2005 YFZ450: Houser anti-vib +2+1 stem, fat bars, durablue axle +2+4, black propegs, black IMS bumper, uni filter with proflo intake, carb bored 2mm, 13:1 piston, Hot Rods crank, "T-Rex" head, full Ron Woods exaust, Aftermarket linkage, steal braided lines, Galfer wave roter, K&K Graphics. much more to come
~Put this in your signature if you or someone you know is fighting, has survived, or has died in a pokemon battle.
#4
Posted 01 March 2004 - 09:11 PM
Lots of fun!
Sure your not too lean at 45ft?
#5
Posted 01 March 2004 - 10:15 PM
Lots of fun!
Im positive, the plug was a dark brown, and it ran great for almost 2 years at 45 ft without fouling 1 plug, even after I got back from Wyoming.
#6
Posted 02 March 2004 - 12:52 PM
#7
Posted 29 January 2005 - 10:37 AM
Quote
Quote
Is the stutter or a burble the same thing?
You say to corrrect this is a fatter needle, or possibly raise the clip to drop the needle farther in to the main. wont this cause your main to lean a lil.
Im runnin mikuni 28mm flatslides with needle #s 5L1 if droppin my needles 1or 2 clips an it dont cure it should I drop it some more? or go with a fatter needle
an would a fatter needle be 5L2. I still need the float height cant find out what it is. I even went to a snowmobile builder to ask an he dont even measure them
#8
Posted 29 January 2005 - 11:31 AM
Under most circumstances, a stutter or burbling wet sound would indicate a rich condition, hence the need to lean a little. Lean conditions often present a flat even bog, and maybe some backfiring or pops. There's exceptions to every rule with jetting, that's why it's so important to read the plugs as well.
In your case, it's extremely important to identify where your stutter is. Is it at 1/2 throttle, full throttle, just off of idle? This will tell you what jetting circuit you must deal with.
As far as finding your float heights, maybe contact CarbParts.com and discuss the float with them and they may be able to give you some insight.
Scott
#10
Posted 30 January 2005 - 10:46 AM
#12
Posted 29 March 2009 - 12:30 AM
Sign In
Register
Help
Back to top
MultiQuote
