easy03
Everything posted by easy03
  1. shouln't be. I checked the boots and filters, made sure the caps on the carbs were tight. As for the junk in the pilots, don't really know. Tried cleaning carefully to see what it is but only an air chuck will get it out (tried catching it). Plus i just found out my timing was 4degrees retarded.
  2. i did when i cleaned the tank both times though both tank and shut off was dirty but not the second time.
  3. 32 to 1, bought new fuel lines, checked gas can and the gas station is good ive always get my fuel their 91octane. im stumped even poured fuel though screens and checked. thats what i was thinking a filter but didnt no if theres a special one to get..
  4. im back with another question. has anyone had trouble with their pilot jets clogging? cleaned fuel tank twice (dirty first time) cleaned carbs no trash at the bottoms. but everytime i ride, start and let it warm up theyre clogged. between 30 and 40 degrees, was using klots r100 friend told me it seperates when cold so switched to lucas. hit me up cause im bout to go to the dark side!!!! oh ya was runnin great on mid to full now bogging.
  5. thanks for the opinions but my stator just died! time to save sum mo money.
  6. hey there fellers, i was needing to buy them (parks, etc.). has anyone used them? toomey says it reduces the dbs and a gain in hp! i have the t6's on it now. just wanting to hear some opinions before i spend $160.
  7. yea im a ratard. didnt do the full thottle test then shut down the engine and let it roll to a stop. thanks for the info i thought it was a little lean in the summer. but im new to this stuff. soon to be a veteran on those tors though!
  8. u were right put a 300 in and still lean. goin for 310-330 tomar.
  9. got a question for ya. can plugs b wet and still run lean? runs great except at full thottle when the bands kick in then it boggs until i let off. also alot of pinging. 270 main 27.5 pilot bout 40degrees out just below 1500 elev.
  10. yeah i was thinkin that. seems like its not gettin enough fuel at full when the bands kick in. it aint like the plugs r gonna b bone dry. thanks
  11. thanks for the reply but i pulled the carb and it was on the second (from top) so tried the first and it still spits and sputters when the bands kick in at full thottle. plugs r still wet so figuring on buying 240-260 and see what happens?
  12. hey uall got a problem. first time postie long time reader. 03 shee boggs hittin powerband, plugs r wet. 27.5 pilot 270 main, elevation 1500, bout 40 degrees. mods r t6 exhuast, hemi head, toomey 2n1 air filter (very small). was wonderin if i could adjust the air screw to lean it out. any idears?
