Boominrick Posted August 25, 2008 Report Posted August 25, 2008 I got a rz motor in my banshee and it's missing the powervalve servo motor and computer, it just has a plate holding the powervalve from moving. Where can I get a PV servo and computer that's not going to cost me a million bucks? Thanks in advance Quote
robley123 Posted August 25, 2008 Report Posted August 25, 2008 as an rz guy I would say those parts are tough to come by. Quote
2strokespirit Posted August 25, 2008 Report Posted August 25, 2008 I see those at least every 4 weeks on ebay... Quote
BenBB Posted August 25, 2008 Report Posted August 25, 2008 Someone said the servo motor is the same for an R1...not sure what year but if anybody knows post it please (and WTF it does on an R1 I thought that was a 4-cyl 4-stroke). Zeeltronic has controllers & CDIs I believe, if you strike out elsewhere you might check them out (I can't say firsthand I haven't)...do you have the RZ stator/flywheel, rectifier, and battery/eliminator or are you running Banshee electricals? Quote
4stroker Posted August 26, 2008 Report Posted August 26, 2008 yeah the R1's have an "EXUP" valve in their exhaust pipes. not real sure on how it works but the servo motor that controls it is exactly the same as the RZ one. there are other yamahas too with this set up, R6s and some FZR600s i think?? there should be plenty around because when they put aftermarket exhausts on them it gets rid of the setup. you can also use R6 or FZR600 rectifiers im pretty sure. for more info see this site: www.rzrd500.com zeeltronic's stuff is meant to be top notch i have the complete package for my bike its getting installed as i type this, watch this space for a full report! Quote
BenBB Posted August 27, 2008 Report Posted August 27, 2008 Thanks 4stroker! I'll be watchin' for the ride report :cool: Quote
