acfine Posted August 14, 2008 Report Posted August 14, 2008 (edited) Hello all, I'm new to the forum and want to start with saying you guys have some really good info here. My question is this: I'm working on a 2003 Banshee, the Limited Edition, and it has 220 main jets. That's the only thing that's been done to it, everything else is stock. When you start off, it bogs badly. When you pull the clutch back in, you have to be really high in the motor to get it to start, but once going, it seems to run fine. It also kicks back on itself at WOT, but this I'm guessing this to be the jets causing the high-end issues. I've disconnected the TORS, and it didn't help... The filter looks a bit dirty, but nothing abnormal, or saturated with gunk. Any help is much appreciated Thanks, Anthony Edited August 14, 2008 by acfine Quote
dhopkins99 Posted August 14, 2008 Report Posted August 14, 2008 doesnt look stock with those fatties on it?? Quote
brugal Posted August 14, 2008 Report Posted August 14, 2008 Try adjusting the airscrews and the idle screws Quote
brugal Posted August 14, 2008 Report Posted August 14, 2008 doesnt look stock with those fatties on it?? That might not be the bike hes working on. Quote
Frogger Posted August 14, 2008 Report Posted August 14, 2008 Hello all, I'm new to the forum and want to start with saying you guys have some really good info here. My question is this: I'm working on a 2003 Banshee, the Limited Edition, and it has 220 main jets. That's the only thing that's been done to it, everything else is stock. When you start off, it bogs badly. When you pull the clutch back in, you have to be really high in the motor to get it to start, but once going, it seems to run fine. It also kicks back on itself at WOT, but this I'm guessing this to be the jets causing the high-end issues. I've disconnected the TORS, and it didn't help... The filter looks a bit dirty, but nothing abnormal, or saturated with gunk. Any help is much appreciated Thanks, Anthony When you say that the only thing that's been done is jets, do you mean that bigger jets were added? It just sounds like the jetting is off/rich. You'll want to check your plugs and see if they look rich. If so start by dropping the main jet down a size. Quote
acfine Posted August 15, 2008 Author Report Posted August 15, 2008 Thanks for the info. And no, the pictured Banshee is mine and not stock, I'm working on a buddy's Banshee. When we bought his quad, we were told time and time again that nothing had been done to it. And later after some calls to him, he said he put bigger jets in it, and that was it. I thought the main jets were mostly for mid to high end, and the pilot jet handles the idle to low end. I'm gonna go through the carbs tonight and check everything. But will start with the plugs as mentioned. Thanks again Quote
