hey guys i need a 69.05 piston for my big bore vito sleaved banshee, but having trouble finding one..was there any other bike/ quad that carried the same piston to have a reference point..
Don't know much about big bores, but bores usually go up at 0.25mm (0.10") a bore.
SP
blaster pistons fit 68 bore long rods. not sur if they go to 69 or not, call a builder and ask them. it will depends on the rod length to determine which piston series you need to run. bore size is only part of whats needed
68.25 is the biggest blaster piston wiseco makes... Biggest piston Vito's makes is a cast @ 69mm
I'd give either Vito's or Trinity a call.. they might have some specialty pistons on hand that will work for you.
the piston is for a stock rod length
