MarineNYC Posted July 23, 2008 Report Posted July 23, 2008 Ok guys. I have like 5hrs ride time on my rebuild. It ran like a bat out of hell the whole time. We get kicked out of the riding area and have to relocate out quads and trucks. I load up drive to the spot and then unload. I start it back up and head out. After about 10 minutes the shee seemed like the rpms were'nt climbing as high as normal which in turn slowed me down because I couldnt hit the peak of the band. But down low the band still hit strong. It almost seemed like it was miss firing. I headed back to camp to check my plugs and they looked great. Something like this happened to me before but it was missing real bad down low. It turned out that the gap on my flywheel pickup was out. So here is my question? Would the gap on my pick up have the same effect if it was out again? Or would it effect it at high rpms as well? And would water behind my stator cover maybee cause this? Because I took off the cover today and I had about two credit card gap between the pick up and had some water that dripped out when I took the cover off. (is this bad?) I reset the gap to the proper setting and cleaned out the water. Cleaned my crab and shee seemed to run fine but I cant really get her open around my neighborhood so I dont know if I really fixed it. Any opinions? Ty in advance Quote
Wildcardracing Posted July 23, 2008 Report Posted July 23, 2008 Those are definately two thing that could cause those symptoms. Quote
xXBlessedWithDeathXx Posted July 23, 2008 Report Posted July 23, 2008 What he said. my mains were small when i had that problem. just a heads up. Quote
locogato11283 Posted July 26, 2008 Report Posted July 26, 2008 whats your jetting bro? any drastic temp changes since the last time you rode?? water in the stator area can def cause some issues. just like water with electricity, that shit doesnt mix well. also, i had my plugs foul one time and i could only feel it on top.. wouldnt rev for shit. ran fine on the bottom and mid, but the top was shit. sure your plugs are alright? if its actin weird maybe because of weak spark it might not be burning all the oil out causing your plugs to foul on the top.. Quote
LS1Inferno Posted July 26, 2008 Report Posted July 26, 2008 (edited) the water could have shorted out the coil a little bit. and the pick up, but same day and after sitting you may just have some dirt in your carbs. EDIT when i say coil i meant coils on the stator. Edited July 26, 2008 by LS1Inferno Quote
