Im not sure if this will help you but I do have a complete vitos big bore cyl and crank kit nd am pleased. I have never ran a cub motor so I cant compare but the vitos rips!! Good customer service too!!
Iv had the vitos 404 kit for many years and its fun and reliable too. I wouldnt get one unless your out of cylinder wall and you need a re-sleeve. If you need a re-sleeve and don't have a fortune, or don't care about having the fastest drag bike on the planet, then the Vito's kit is an inexpensive alternative to aftermarket cylinder kits.
The kit his is talking about is an aftermarket cylinder kit. They look almost like stock oem cylinders. If your looking for all out HP then the cub is the way to go. Vito's kit would probably be good for some one wanting a big bore kit with out the drag porting that a cub has.
