burnthenikle Posted July 14, 2008 Report Posted July 14, 2008 ok is there a thread on this somewhere? trying to get the brother-in-laws qaud ready for when he comes home thanks! Quote
LS1Inferno Posted July 14, 2008 Report Posted July 14, 2008 ok is there a thread on this somewhere? trying to get the brother-in-laws qaud ready for when he comes home thanks! WTF are you talking about? Quote
Misssppelllleddd Posted July 14, 2008 Report Posted July 14, 2008 Are you trying to put a R6 shock on a 'shee? Why the fuck would you do that? Quote
sheefreak Posted July 15, 2008 Report Posted July 15, 2008 You have to drill the shock to accept the stock bolts. Not shure what size. The bottom eyelet is hardened and is a bitch to drill. You will want to address the front as well though, you will be loooowwwwww in the rear. 300ex shocks work perfect to level her out. They bolt right up. I purchased the newer style R6 shock w/the rezzy up and down instead of sideways(red spring as well). Jt turned me on to this setup and he may be more help. It works absolutely perfect w/10 in swinger for height and valving. Quote
burnthenikle Posted July 15, 2008 Author Report Posted July 15, 2008 You have to drill the shock to accept the stock bolts. Not shure what size. The bottom eyelet is hardened and is a bitch to drill. You will want to address the front as well though, you will be loooowwwwww in the rear. 300ex shocks work perfect to level her out. They bolt right up. I purchased the newer style R6 shock w/the rezzy up and down instead of sideways(red spring as well). Jt turned me on to this setup and he may be more help. It works absolutely perfect w/10 in swinger for height and valving. is there any way i can see a picture off shock installed? if i have to drill it our so be it... but wondering how this is done... it is also the the newer R6 shock with red spring... thanks for the info! Quote
badassbanshee479 Posted July 15, 2008 Report Posted July 15, 2008 R6 Rear shock, 300ex front shocks, link style swinger, 10 over. The shock works really well as long as your not a real heavy guy! Its a tad soft with my 250lb ass on it but it works great for my bro who is 155. Yes you have to drill the sleeves alittle bigger to accept the stock bolts. I tried drilling the hardened sleeve with no luck so I just spun a new one up on the lathe at work. I am sure you could drill the sleeve with alittle effort I like to play on the lathe when theres nothing going on. Here is a pick of my bike with the shock on it Quote
burnthenikle Posted July 15, 2008 Author Report Posted July 15, 2008 R6 Rear shock, 300ex front shocks, link style swinger, 10 over. The shock works really well as long as your not a real heavy guy! Its a tad soft with my 250lb ass on it but it works great for my bro who is 155. Yes you have to drill the sleeves alittle bigger to accept the stock bolts. I tried drilling the hardened sleeve with no luck so I just spun a new one up on the lathe at work. I am sure you could drill the sleeve with alittle effort I like to play on the lathe when theres nothing going on. Here is a pick of my bike with the shock on it cool...yeah it seems to be a little soft...but did you have to do something to the shock to make it longer? Quote
badassbanshee479 Posted July 15, 2008 Report Posted July 15, 2008 nope, but I did machine a spacer to put alittle more preload on the spring. other than that it bolted right up! Quote
burnthenikle Posted July 15, 2008 Author Report Posted July 15, 2008 nope, but I did machine a spacer to put alittle more preload on the spring. other than that it bolted right up! really...hmmm i bolted it right up and sit's really low... well thanks for the info Quote
badassbanshee479 Posted July 15, 2008 Report Posted July 15, 2008 thats what its designed to do. then ya run 300ex shocks on the front. I run this setup to lower the bike down for drag racing. Quote
