TRO73 Posted July 14, 2008 Report Posted July 14, 2008 Hi, Just recently rebuilt my top end and switched to 35's...First only one cylinder was firing and got the other to finally fire"THANKS TO KEVIN HERR" the carbs seem off alittle before I started it the slides looked like they were in sync but besides the idle screw is there other adjustments i need to make? I had to choke the right carb to get it to fire them had trouble getting it to start finally got it running and it seems the left is a little stronger than the right "JUST HEARING IT IDLE AND WHEN YOU GIVE IT GAS" dont have the chain on yet so have not rode it. Had to quit off the night before I started to piss off neighbors and my wife. :biggrin: Any help would be great, Thanks Tony Quote
KEVSWS6 Posted July 14, 2008 Report Posted July 14, 2008 Have you adjusted the sir screws at all? 1 to 2 turns out from bottom. Quote
TRO73 Posted July 14, 2008 Author Report Posted July 14, 2008 Have you adjusted the sir screws at all? 1 to 2 turns out from bottom. Thanks Kevin I'll try that...Also how the hell do you get to the right carb idle screw with out using pliers? Quote
Animalman294 Posted July 15, 2008 Report Posted July 15, 2008 I just use a small screw driver........... Quote
huskyohilux Posted July 16, 2008 Report Posted July 16, 2008 Thanks Kevin I'll try that...Also how the hell do you get to the right carb idle screw with out using pliers? Remove the cap on the carb when you turn the idle screw, otherwise the springs Quote
baddsheee Posted July 16, 2008 Report Posted July 16, 2008 Remove the cap on the carb when you turn the idle screw, otherwise the springs Quote
FireHead Posted July 16, 2008 Report Posted July 16, 2008 I'm not a pro on these, but can't you just open the throttle and then adjust instead of removing the cap. Haven't tried it but would make sense. Plastic screws That's what I did with mine before buying metal screws. I don't know why removing the cap is a good idea to do that work. Quote
