I was wondering the quality of the Rickey Stator adjustible timing plate. I herd alot of negative things about there stators. Just wondering if I should buy one or go with the trinity plate. Any info would be great.
the plates are junk also. while mounting the pick up coil i spun and stripped 1 screw 1 st try.
Thanks for the info NYUK. I'll just go with the better one. I'd hate to end up buying 2 of them.
I think you will be happy with a billet plate. I know I am, it was worth the $80 I spent on a Pro Design. I believe the Chariot Racing (?) plate is a little less expensive. :thumbsup:
ive got 2 of trinitys timing plates and i like them. it adjusts the pick up only. the whole plate doenst adjust, it gets mounted via the three holes and you undo 2 small allens and move the pickup to the desiered degrees.
Fuck ricky stator and trinity go with the Chariot plate. Alot of people say the plate don't have stress so it don't matter what you get "bullshit" if i were you i'd go with the chariot plate what's another 30 bucks gonna do to you. The concept is when your riding you know you have some strong shit that you don't have to worry about.
so is trinitys adjustable timing plate crap? cause i have two of them and just curious if i should expect problems with them.
I havent herd anything bad about them, there just more money.
