will fox Posted July 12, 2008 Report Posted July 12, 2008 i have a 1989 banshee that hasnt ran since 1998 and needs to be taken apart and cleaned were should i send it and i need a place close to st.cloud MN and wouldnt be to expensive Quote
HammerShee99 Posted July 12, 2008 Report Posted July 12, 2008 Your cheapest bet is to buy a Clymer's manual and do the job yourself. Clymer manuals tell you pretty much everything you need to know, and they have fairly clear pictures so you know what they're talking about. Plus that way if you need to replace any parts in the future you can save yourself from having to pay for shop labor if somebody else does it. Quote
jbooker82 Posted July 12, 2008 Report Posted July 12, 2008 I would just pull the head off and look at the cylinders. See if they are rusted. If not I would clean the carbs check fluids and fire it up. Then drain the oil and coolant and put new in. josh Quote
jbooker82 Posted July 12, 2008 Report Posted July 12, 2008 I would also put a little 2 stroke oil in the crank case and on top of the pistons. I am sure that everything is going to be dry. josh Quote
will fox Posted July 12, 2008 Author Report Posted July 12, 2008 thanks wut about a new clutch im not sure exactly wuts wrong but it doesnt shift very easily and sumtimes not at all Quote
spurdy Posted July 12, 2008 Report Posted July 12, 2008 thanks wut about a new clutch im not sure exactly wuts wrong but it doesnt shift very easily and sumtimes not at all If it isn't running it won't shift very well. It is a "constant mesh" tranny and the primary and counter shafts need to be spinning to run through the gears. I would drain the oil in the tranny and see what it looks like and then refill if it looks ok. Then I would do what Josh said. SP Quote
