k the cylinder closest to the kick starter would turnover fine but only like halfway and then it would stop so long story short i kicked it over and it spins fine now but theres a SHIT load of metal chunks in the oil so what happened.... any ideas?
id bet it ate 3/4 of a piston, or gouged like 34mm of the cylinder. :blink:
why in the fuck would you keep kickin it over if it wouldn't go? that's like punching yourself in the face...you know it's gonna hurt and do some kind of damage
I'd say you need to split the cases and clean it all up good, especially with the multitude of other things wrong in other threads. Just tear it down adn start over fresh. Buy a clymers, take a weekend and do it.
check your clutch basket. That sucks when stuff breaks.good luck. Didnt you just get you stuff back from Kevin?Did the bike run before. I dont get it.
Edited by shee4speed
Metal in the oil could be from the clutch basket, kickstarter gear or idler gear clip...but not from damaged rods or pistons.
yes, i was just kidding. just start lookni around, if theres that much in it you should see something thats not right.
Yeah I figured that. I've read enough of your posts to know that you're more savvy than that when it comes to these engines.
ya its not the pistons or cylinders because they werent on the bike, so should i just take the side cover off and look because to be perfectly honest i dont trust my self to split the cases and put it back together
hell you haven't even taken the clutch cover off :blink:
yes. do that. look at everything. if something is really shiny or scarred up, thats where it came from most likely
  • 2 months later...
