SPLIT THE CASES ALREADY....with all the time you've spent looking for a magical answer, they could've been split, cleaned out and the damage tallied....
The only way a piston, rod, bearing, etc, could have pieces in the gear box is if you broke something and it put a hole between the crank case and the tranny....you'd have MUCH Bigger problems then.
Edited by dajogejr
