mississippi banshee Posted July 6, 2008 Report Posted July 6, 2008 (edited) what does it do and would it be good for a trail bike i saw what looked like a trail bike with one it was yellow with tsl's on it Edited July 6, 2008 by mississippi banshee Quote
BellicoseBanshee Posted July 6, 2008 Report Posted July 6, 2008 what does it do and would it be good for a trail bike i saw what looked like a trail bike with one it was yellow with tsl's on it A lockout clutch is used on higher powered engines to prevent the clutch from slipping and burning up. I am not sure exactly how much power warrants the need for a lockout, but a piped banshee with basic bolt-on parts should not need anything more than a heavy-duty clutch at most. I would not waste money on a lockout unless the engine requires one. A FAST clutch, for example, will take a pounding and will only cost about $100.00. The ~$50 Tusk HD clutches are decent as well. Quote
LS1Inferno Posted July 6, 2008 Report Posted July 6, 2008 yeah a lockout if pretty much for race bikes and high power hill/dune shooters. you DO NOT want one on a trail bike Quote
FireHead Posted July 6, 2008 Report Posted July 6, 2008 A lockout clutch is used on higher powered engines to prevent the clutch from slipping and burning up. I am not sure exactly how much power warrants the need for a lockout, but a piped banshee with basic bolt-on parts should not need anything more than a heavy-duty clutch at most. I would not waste money on a lockout unless the engine requires one. A FAST clutch, for example, will take a pounding and will only cost about $100.00. The ~$50 Tusk HD clutches are decent as well. If I were to make up a horsepower number for when you ought to start looking at lock up clutch, it would probably be about 80hp. :geek: Quote
