TRO73 Posted June 30, 2008 Report Posted June 30, 2008 Hey guys bought a sync tool and I am getting some new carbs but the tool came with no directions what so ever..I know the tool goes in the back of the carb but if running a airbox one carb will be exposed when running? Any info on this would be great. Thanks Tony Quote
magz Posted June 30, 2008 Report Posted June 30, 2008 theres a video of how to do it somewhere around here...did you try the search button first? Quote
jbooker82 Posted June 30, 2008 Report Posted June 30, 2008 Just sync the carbs with the air box off. Hold the gauge against the carb. You want slack in the cable. Adjust the idle speed screws until you get the same number and Idle speed you want. Then you need to take all the slack out of the cable and have a high idle. Then you adjust the tops of the carbs until you get the same number. That insures both carbs will opean the same. josh Quote
wesw Posted June 30, 2008 Report Posted June 30, 2008 http://www.bansheehq.com/forums/index.php?showtopic=95025 Quote
TRO73 Posted July 1, 2008 Author Report Posted July 1, 2008 http://www.bansheehq.com/forums/index.php?showtopic=95025 Thanks wesw....Very Helpful Quote
