my rear brake pedal is so high that its ripping into the clutch cover.the master cylinder has been rebuilt,the brakes are worn but not done.and if there was a pin hole leak in the line wouldnt it squirt brake fuid atleast alittle.
every month i have to bleed the brakes to get pressure back to the pedal.i dont notice any brake fluid puddles either.please somebody help me figure this out.
Do you know there is a pedal height adjustment tie rode between the pedal and master cylinder? :ermm:
  • 2 months later...
The Shee I just got has the same thing wrong man..People who had it before didnt mess with the pedal adj an theres a good size worn spot on the clutch cover..grr
