stephaner142 Posted May 28, 2008 Report Posted May 28, 2008 I went for a little ride with my daughter for 45 min. I took it easy, didn't go past 2nd gear. It ran just fine. I droped her off at home and went for a realy good rip for 20 minutes and wen I let off the gas she wont idle down. It feels like she stays at 1/2 throttle and wont idle down. is this because she is runing hot or what. I gave the motor new seals last week. cleaned the crabs, checked the boots, she still has stock bore with 120psi on both cylinders and I just installed boysen two stage reeds. I turned the air screw down 1/2 turn like the instructions sead. does anyone have any ideas. Quote
locogato11283 Posted May 29, 2008 Report Posted May 29, 2008 sounds like it could be an air leak. what all did you replace? did you put new intake gaskets on? did you make sure the carbs went back together correctly? Quote
stephaner142 Posted May 29, 2008 Author Report Posted May 29, 2008 yep, I added new gaskets when I changed the reads. and carbs are on properly. I talked to my brother and he says its just a carb tuning problem. I checked the plugs and they're a little on the rich, I've got stock 200 mains. I went for a ride with my brother last night and in an hour I went through 3/4tank of gas and my brothers yfz 450 only burned 1/4 tank. Is it normal for her to be that hard on gas. Quote
FireHead Posted May 29, 2008 Report Posted May 29, 2008 sounds like it could be an air leak. what all did you replace? did you put new intake gaskets on? did you make sure the carbs went back together correctly? Word. I doubt it's a carb tuning problem.:geek: Quote
