everything with my motor is fine good comp and all. I'm just having problems starting it with my keihin 28mm pwks it doesnt matter if it hot or cold. If its cold it will start without choke on after about 5-8 kicks when its warm 2-4 kicks..
It doesnt load when it is idling it will idle all day long and you can go burp it and it will take right off just a lil hesitant, i spent this evening tinkering with it abit the airscrew is 1/2 turn out i moved the the needle up one spot and that got it to start just a tad easier..my question is should i go with a smaller pilot or a larger pilot..i searched a bit but got controversial answer as to which way the pilot needs to go..
keep in mind the airscrew is only 1/2 out and it doesnt load...
45 pilot
MJN needle 2nd clip from bottom
150 main...
