twizted269 Posted May 22, 2008 Report Posted May 22, 2008 i just rebuilt my engine with .40 over and an new wiseco crank. everything installed right to the t but get a knocking noise when running. noise isnt really noticeable unless sitting at idle. sounds like in the jugs but cant tell for sure. is it normal to hear engine noise or tranny noise over the engine? i have a buddy with the same setup and sounds close and another buddy at stock but not near as loud. after the secong engine overhaul in 2 months i dont need an more problems. any ideas would be nice. Quote
FireHead Posted May 22, 2008 Report Posted May 22, 2008 i just rebuilt my engine with .40 over and an new wiseco crank. everything installed right to the t but get a knocking noise when running. noise isnt really noticeable unless sitting at idle. sounds like in the jugs but cant tell for sure. is it normal to hear engine noise or tranny noise over the engine? i have a buddy with the same setup and sounds close and another buddy at stock but not near as loud. after the secong engine overhaul in 2 months i dont need an more problems. any ideas would be nice. You probably need to measure youre squish band to see if you are maybe way out of tolerance and have the piston hitting the head. Quote
okbeast Posted May 22, 2008 Report Posted May 22, 2008 I can hear tranny noise on mine, or something that sounds like it, along with bolts rattlnig loose, kicking rattling, exhaust tinging, I just ride the damn thing Quote
ItzaBansheeBitch Posted May 22, 2008 Report Posted May 22, 2008 Sounds like shirt slap. Have you checked the rig gap clearance? have your jugs checked, who ever did your work might have gotten a little out of spec. Quote
g-force Posted May 22, 2008 Report Posted May 22, 2008 I've had that noise for years, before and after rebuilds and have seen several posts on this subject. I can't figure out what the noise is, I just don't worry about it anymore. Quote
banshee(911) Posted May 22, 2008 Report Posted May 22, 2008 *Skirt slap was wondering if you changed the bearings in tranny or on clutch Quote
papa_smurf49319 Posted May 23, 2008 Report Posted May 23, 2008 mine has a little something to it also, but nothin to worry about and its not crazy loud, only noticeable if your listening for it! Quote
twizted269 Posted May 24, 2008 Author Report Posted May 24, 2008 i know its not skirt slap or anything to do with tolerences with the jugs or crank. i mic'd everything and its within specs. crank is brand new. locoal shop just said its normal for these machines to make some noise when everything is that tight. still sounds weird though. Quote
papa_smurf49319 Posted May 24, 2008 Report Posted May 24, 2008 just ride the damn thing, i know your worried because its a new motor, trust me ive been there. But just go have fun on it!!!!!!!!! Quote
hillshooter421 Posted May 26, 2008 Report Posted May 26, 2008 I have had a noise in mine for a while now, the noise in my motor is the kick start gear. I can only hear it when im at idle. check it out, the gear is just held on by a clip and if its worn out it rattles. Quote
