buchs8 Posted May 17, 2008 Report Posted May 17, 2008 I recently put in Vforce 3 reeds in and now when i try to start it it wont idle or kick start. the only way i can get it running it to pop start it. i am completely lost please help. Quote
shee4speed Posted May 17, 2008 Report Posted May 17, 2008 When you put the carbs back on,did you reinstall everything? Choke tube? When you get it going does it run okay? Quote
blowit Posted May 18, 2008 Report Posted May 18, 2008 Slides in backwards. Please make sure chamfer on bottom of slides is on the filter side. Quote
locogato11283 Posted May 18, 2008 Report Posted May 18, 2008 Slides in backwards. Please make sure chamfer on bottom of slides is on the filter side. hmm, cant imagine why the carbs would have been apart.. buchs, did you take the carbs apart when you did this? did you rejet at all? did you change anything else? Quote
