Got my motor running!! Runs great but I have a problem.
I put new fuel line on and this is my first time running my PWK 28's and the 1/4" fuel line fits really loose on the carbs and leaked really bad. I went to Autozone and got some "quick clamps" and the leaking stopped but I'm worried if this will cure the problem or if it will crop up again...
Do the PWK's use a smaller size fuel line??
:confused:
When I had my 28's I just put zip-ties on the fuel line at the carbs and never had any problems. I think you set-up should be fine. By the way I ran mine with 28's and zip-ties for 7years... :biggrin:
mine are like that too, it kinda pisses me off.
:confused:
I got new fuel lines from the T to the carbs because of that, never would of thought they would be different size, they were pretty loose Id get smaller lines when ever you get a chance.
I'm gonna measure the barb on the carbs and see what they measure... 1/4" fuel line is definately loose, I even tried the OEM lines that came off of my stock carbs and they are loose too. Everything I tried fits tight on the T and petcock though.
I just dropped down on size from T to the carbs it will be tight on T but it works and used stock lines on petcock to T.
PM theshee i got some fuel lines from him, note that i haven't put them on yet but i think the lines i got from him are the ones he ran on his bikes. He has em' in different colors i don't know if he's selling them on the side or what. Can't hurt to ask.
Yeah, hit me up if you need some line. I have Blue, red, yellow, orange, clear, and pink.
well that sucks man, the squeeze and release clamps should work.
do the stock carbs take 1/4" fuel line? and is 3 feet enough for both carbs?
Sorry bout the hijack
