omalavet Posted April 25, 2008 Report Posted April 25, 2008 i bougth a used shee 2005 and every morning that i want to start it it wont start i HAVE to use the engine start fluid to start it then wen i put fuel in again even when hot it dosent start once again and some time wen i go really fast in six gear for a long period and then i come to a stop and it wont start....HELP Quote
Screaming Yellow Zonker Posted April 26, 2008 Report Posted April 26, 2008 You might want to pull your carbs off and clean them. Most likely your pilot jets are gummed up. You could also try turning your air screws in a quarter turn at a time this might help. Good luck. Quote
hylander88 Posted April 26, 2008 Report Posted April 26, 2008 also might want to check for spark to if weak also will do the same thing...also check gap between fly wheel and the coil...will also give you a weak spark..that how mine was fixed the gap fire up one kick... Quote
omalavet Posted April 26, 2008 Author Report Posted April 26, 2008 You might want to pull your carbs off and clean them. Most likely your pilot jets are gummed up. You could also try turning your air screws in a quarter turn at a time this might help. Good luck. i didnt pull the card off at this time i just adjust the screws and wont start in the cold im from puerto rico so a cold start is like 75-80f Quote
omalavet Posted April 26, 2008 Author Report Posted April 26, 2008 also might want to check for spark to if weak also will do the same thing...also check gap between fly wheel and the coil...will also give you a weak spark..that how mine was fixed the gap fire up one kick... yeah at frist it was that gap that could not get the shee started but ive already fix that and now is something else i dont now Quote
mopar1rules Posted April 26, 2008 Report Posted April 26, 2008 what's the gap between the flywheel and coil suppose to be? Quote
omalavet Posted April 26, 2008 Author Report Posted April 26, 2008 what's the gap between the flywheel and coil suppose to be? i dont now the real # but mine is almost touching the little metal part of the fly wheel all i now is that it has to be really close try to find it n the manual download it here http://www.bansheehq.com/forums/index.php?showtopic=68045 Quote
mopar1rules Posted April 26, 2008 Report Posted April 26, 2008 i couldn't find anything in that downloadable manual. anyone know the proper gap on the pickup coil to the flywheel? Quote
_Hex* Posted April 26, 2008 Report Posted April 26, 2008 the proper gap is .22, also check the pickup coil on the top under the fuel tank Quote
Misssppelllleddd Posted April 27, 2008 Report Posted April 27, 2008 I had the exact same problem before except my shee is 1987. My stator coil went bad on me which it shouldn't go bad already with a 2005. You might want to try getting a multi use voltmeter. The one that also measures amps and ohms. Get your hands on a Clymer manual and start checking the electrical system. It is a pain in the ass but it helped me with finding my problem. Quote
