Midway USA Posted April 23, 2008 Report Posted April 23, 2008 What is the difference between the 87-89 spindles and the 90-06 spindles? I have a bent spindle on my ride and I took a chance on an E-Bay spindle that cost me $8.00 shipped. It appeared to be the same in every way to mine except the spacing on the brake caliper mounting holes was closer together than mine. I ended up heating and straightening my spindle for now and it seems to be good. I need to put the one I bought back on E-Bay but I just wanted to know what exactly it fit first. Thanks for any help. Quote
locogato11283 Posted April 23, 2008 Report Posted April 23, 2008 87-89 frames were j-arm frames. the 90-present are a arm frames. as for he spindle itself i dont know the difference. i just know that the first 3 years used j-arms. Quote
hylander88 Posted April 26, 2008 Report Posted April 26, 2008 (edited) the mounting holes are different for the calipers .........what year is yours i bought the whole front end off e-bay too.. and the spindles were different too...so i cant say when they change them mine is an 88..and it has the bigger pattern... Edited April 26, 2008 by hylander88 Quote
Midway USA Posted April 27, 2008 Author Report Posted April 27, 2008 the mounting holes are different for the calipers .........what year is yours i bought the whole front end off e-bay too.. and the spindles were different too...so i cant say when they change them mine is an 88..and it has the bigger pattern... Mine is a 98. Originally was told it was a 96 but found the numbers charts in a pinned post here and confirmed it is a 98 engine and frame. I am assuming still all original but you never know. According to the parts lists I have looked at the 87-89 have one part number and the 90-06 have a different number. I assume based on what I saw they would interchange if you used the matching brake calipers. Everything else appeared to be the same. Quote
