BrianEb Posted April 21, 2008 Report Posted April 21, 2008 My other friends banshee when he gets it started when you blip the throttle it just want to stay at high revs I don't know if he need a new throttle cable he has an aftermarket moose throttle i dont know if its play in the cable by where it connect to the throttle lever or if is something electrical hes put a new CDI Box on and a New Ing Coil looking for help Quote
BaNsHeEs RuLe! Posted April 21, 2008 Report Posted April 21, 2008 Check the slides, sounds like a slide is backwards. Or both slides. Quote
BaNsHeEs RuLe! Posted April 21, 2008 Report Posted April 21, 2008 also, check the adjustments on top of the carbs, make sure the slides bottom out. sync' em, and you should be good. Quote
Dinner Posted April 21, 2008 Report Posted April 21, 2008 Hmm, could even be moisture in your carbs that are causing the slides to stick. I would take the carbs apart and give them a good cleaning first. Quote
