Have to get it running by friday..
I absolutely can not get it to idle.. Off the start it bogs real bad but rip up top...I'm running pro circuits ported, vf3's. The carb is a 2 into 1 with a keihin 35m. Main is a 190 and the pilot is a 55 air scew 1 1/2 turns out with the clip in the middle. I'm 200 above sea level at 70 degrees.. I believe the pilot may be too big. if I try starting out in 2nd to get up a hill it will actually stall..
I am having trouble with the same set up. So far I know you need to make sure the float is set at 11mm from the crease on the float itself across from your needle and seat. The needle is also a big deal on those carbs. The cosensus here is to use a EEJ needle. I am at sealevel and have a 48 pilot. Hope it helps you some.
What needle? Your pilot is too big also.
