2strokespirit Posted April 11, 2008 Report Posted April 11, 2008 Hi this is the pic of the 4mm long rod stroker cranks which I can buy as a dealer from Taiwan for about $160 - $200. Can someone identify it as a name brand crank? Vitos does not make a 4mm Long rod as far as I know, so for who else will these be made? There is a number on the conrod, G - 115. I have a few questions, can one use Yamaha big ends in a hotrods crank if you want to rebuild? http://img182.imageshack.us/img182/8632/dsc001193sl6.jpg I found this on e-bay and if you look at the pics, it runs with the same mains as this hotrods, the only thing that are differant is the spacer between the inner mains have 2 o'rings instead of one. http://cgi.ebay.com/ebaymotors/HOT-RODS-HO...sspagenameZWDVW Quote
2strokespirit Posted April 13, 2008 Author Report Posted April 13, 2008 I have put the crank into one of the casings and it does not fit, I have measured the pin to the side of the web and it is about +- 3.25mm more off set than a standard crank, so I guess its a 7mm stroker... Quote
2strokespirit Posted April 13, 2008 Author Report Posted April 13, 2008 time to trench some cases? This is all going into a RZ banshee, but yeah maybe, otherwise I will get a 4mm!! Quote
Animalman294 Posted April 13, 2008 Report Posted April 13, 2008 Gotta love Taiwan.................. Quote
