Hey guys, ran the shee out on the dunes last week, and it would only fire on 2 cylinders 50% of the time, I took it in to Yamaha and they spend 4 hours looking at it and couldnt figure it out, the put in a new coil and wires, cdi box and looked at the wiring harness, they said my stator is in rough shape but it either works of it dosent...
any ideas to what it could be
thanks
If it was running only 1 cylinder 50% of the time you have to narrow it down to either fuel issue, compression, or spark then work the problem. Sence the dealer already checked most of your electrical I would start with the other stuff. What does your spark plugs look like? Do a compression check in both cylinders. Clean your carbs and check your float level one of your carbs could be adjusted wrong and your running your float bowl dry. I would imagine the dealer ohmed out all your electrical components but who knows I would do that to if I where you. But like I said I would check out the fuel system and compression then rule them out and then work on the electrical gremlin
The dealer also did a overhaul on the carbs, i went to go work on it today and start it up and it wouldnt even start, to me it seems like its flooded from sitting. The fuel is off but do you guys run your banshees out of gas before storing it for a few weeks???
It ran on 1 cylinder out of the trailer and into the garage, now it wont even start?
Just wondering if it could be flooded?
I run mine out of fuel everytime I know I'm not going to run it for a few weeks. Mine is doing something similar but the right plug is white and the left plug is brown on the plug chop. I think that mine is either in the coil or my plugs wires may be screwed up. Still have to tinker with mine to narrow it down, but in your case you are going to have to check things and recheck things. It's a pain in the a$$, but you will eventually find it.........
Sounds like the same problem. plugs are white and one brown but its strange that i have spark on both cylinders... humm banshees :confused:
we had the same problem this weekend. we replace the cdi, coil, plugs, stator, still no workie. but we finally figured it out....check your reeds. we pulled them out and one petal was broken in half. I thought it was the coil. my bike acted the same when i had a bad coil. but i guess you can get the same symptoms with 2 diff problems. i'd say you have a reed issue
I did a compression test, 125 and 123, still wont fire, i pushed it around the street in gear with the plugs out to clear out anything, still wont run, or even start. I have spark. Reeds are in the carbs correct?
sorry i am still new at banshees and atv world and still learning
the reeds are between you intake boots( rubber that your carbs go into) and your cylinders. you can usually just take your carbs ou and look in with a flashlight. but i perfer just to take them off and inspect them. there is 4 bolts holding the rubber boots anr reeds in on each side.
So did you figure it out yet taylor...your proly dieing to tear ass around on the old girl hey :biggrin: You will have it going in no time i bet man :thumbsup:
Pulled the carbs off, Reeds look fine, float levels are good also
So heres the thing, when its running the right side isnt firing. it pukes out oily gas out of the pipes, but yet the spark plug is hot and clean.... what gives? Left side of the pipe is smokin hot and the right side is cold.
Check the gap on your pickup coil should be 15 thousandths. Also make sure your choke crossover tube is in place between the carbs, and make sure the slides are not in backwards
On mine the reeds are brand new only been out on them twice in the sand, so I doubt it is that, plus compression is at 185 both sides. It is sparking on what I call the dead side, but the plug is white. I also notice that when I run the bowls out the right side takes longer to drain the bowl down. I'll have to check the gap and my coil/wires.............
