Anybody know a good place to buy carbs from? I'm currently running the stockers and really need an upgrade. I dont want to go any bigger than the 34's. I just recently got my banshee and I can tell that the stock carbs are holding it back, any help is good help
Jeff at F.A.S.T. can hook you up. The guy knows his shit, and takes pride in his work so you know your getting the best. Check out his website. He has carbs starting at $142.50 i believe. He'll take care of you
:thumbsup:
Aaron
i bought my mikuni tm 34s from 1dirracing.com . $ 187 a piece. pretty good deal. they also came pre-jetted. they were set up pretty close too. just off by a couple of jet sizes (rich).
Get a set of Keihin PWK 33's from jeff at fast. I got mine from him for around $350. That was for carbs, cable, taller carb top adjusters, metal idle adjustment screws, and ez pull slide springs. He also sells a billit intake that has a built in crossover tube. It is thicker and angled so it moves the carbs up and back so the left carb bowl doesnt hit on the clutch arm. Get one of his carb sync gauges too. Makes syncing the carbs ez and dead on accurate.
