does anyone have a good trick for putting rings in without a ring compressor on the banshee. just got the top end bored and i was wondering if anyone had any tips on putting it back together. mainly the ring installation. i tried the search engine but didnt find much of anything on this. thanks for everything.
first off you need to make sure you have the correct gap. to do this put the ring in the cylinder and use the crown or top of the piston to push it inside the cylider and make sure its level. use a feeler gauge and messure the gao, depending on your bore size and type of piston will determine what size gap you need.
once your gap is set put the ring on th piston and connect it to the rod. if you look at the bottom of the banshee cylinders they have a little bit of a taper, so you dont need a ring compressor. you may have to squeeze the ring by hand a little bit but for the most part it should slide right over
the bottom of the cylinders are tapered so makes it so you don't need a ring compressor.just make sure you put some oil on the pistons, rings and inside the cylinder.
