04YAMSHEE Posted February 26, 2008 Author Report Posted February 26, 2008 also noticed that last time i topped off my coolant it is over the full line in the resivoir Quote
rubberneck Posted February 26, 2008 Report Posted February 26, 2008 i've talked to 3 of my buddies with banshees and they said all of theirs leak out of that overflow tube. Um ok, do what you want. You asked what caused it, we gave ways to find out. My bikes dont puke at all. Can ride for days on end throught the dunes and not a drop unless something isn't right. take it for what its worth Quote
04YAMSHEE Posted February 27, 2008 Author Report Posted February 27, 2008 well i wasn't being a dick i was just posting information. anyways, i put the new impeller in, refilled the coolant and drained some out of the resivoir. started it up and brought it up to temp, no bubbles present. shut it off and pressure tested the system, no leaks. put the cap on and ran it for a while in the garage and no coolant. i should be good to go. Quote
NitroTate Posted March 17, 2008 Report Posted March 17, 2008 Ok after a bit of searching to no avail... I'm going to resurect this posting... I'm having almost the same issue here. Mine will create a small pool of antifreeze out of the overflow tube about 5 inches in diameter after reaching about 190-200 deg. It's not pissing really bad but just wondering if I have an issue? Here's the things I've already checked: Brand new rebuild No bubbles inside while running so don't think it's head. (Brand new orings in coolhead) definitely from overflow tube, I have a clear tube and can see it coming out Just put in a brand new billet impeller Haven't done a pressure test, can someone explain how please? Let me know if you guys think I have an issue here? thanks Quote
Bansh-eman Posted March 17, 2008 Report Posted March 17, 2008 how old is your cap? could be ready to replace? Quote
Hulio-mv Posted March 17, 2008 Report Posted March 17, 2008 I am having a bit of the same problem the way to tell if it is the compression doing it is when you first start it put your fingher over the end of the overflow tube and see how big the bubbles get with the engine cold my bubbles get big and the coolant keeps coming Quote
NitroTate Posted March 17, 2008 Report Posted March 17, 2008 The cap could definitely be the prob I don't know. I can only assume it's the original 1989 cap... I think I'll swap it with my wifes banshee and see... As far as the bubbles go, what do you mean? I'm not quite following you because the overflow hose comes out of the very top above the coolant level in the radiator so it wouldn't be bubbling anyway and if the cap is on you can't see anything anyway. Can you explain a little further? Thanks for the help Quote
Hulio-mv Posted March 17, 2008 Report Posted March 17, 2008 the overflow tube ends up right above the pipe on the right side of the bike it is tied up to the frame. pull it out where you can see the end of it. start the bike cold and put your finger over the end of it maby with some spit or soap and see if it makes bubbles if it does you are getting compression in your cooling system Quote
NitroTate Posted March 17, 2008 Report Posted March 17, 2008 the overflow tube ends up right above the pipe on the right side of the bike it is tied up to the frame. pull it out where you can see the end of it. start the bike cold and put your finger over the end of it maby with some spit or soap and see if it makes bubbles if it does you are getting compression in your cooling system Ahh gottcha. ok thanks Quote
