Isaac_62 Posted February 19, 2008 Report Posted February 19, 2008 Guys, I need to replace my oem axle, axle carrier, sprocket hub, Brake hub, etc... I have a 95... Are the parts interchangable if i was to buy something used but newer. Do all years fit?? Thank you Quote
locogato11283 Posted February 19, 2008 Report Posted February 19, 2008 yea i think you should be fine getting newer parts. as far as i know nothing changed from 95 till now. pm NYUK. hes prolly got everything you need laying around. Quote
NN2 Posted February 19, 2008 Report Posted February 19, 2008 Guys, I need to replace my oem axle, axle carrier, sprocket hub, Brake hub, etc... I have a 95... Are the parts interchangable if i was to buy something used but newer. Do all years fit?? Thank you You should have asked if anyone knew any special tricks to getting the whole axle assembly apart. So I'll ask. How many have had their axles permantely stuck to the splined rear sprocket hub? Did you ever get them apart? Seeing how he's already put over 15,000 lbs of pressure trying to press his axle out, I don't think he's going to get it, hence the reason he's asking about all the other parts :biggrin: Quote
