2/2 many banshees Posted February 17, 2008 Author Report Posted February 17, 2008 so there would be two 2 temp. guages one v1 in each pipe?? one in each pipe no v sory Quote
gentner8 Posted February 17, 2008 Report Posted February 17, 2008 have somebody put a weld on them to close them correctly. I wouldnt try jb weld because I think it wouldnt last. just my .02 Quote
BigRed350x Posted February 17, 2008 Report Posted February 17, 2008 (edited) right now it run 100% it's the fastest banshee I have ever rode you must not have ridden very many banshees then. If its rockin fatty's its not that fast. edit: lots of companies out there make egt sensors that only require a hole and are held in place with a pipe clamp. Its what I run on my methanol bikes. If the holes are about 6" from the head of the pipe thats what they are for. They are hurting performance if they are not plugged. Have a welding shop close them up. Edited February 17, 2008 by BigRed350x Quote
2/2 many banshees Posted February 17, 2008 Author Report Posted February 17, 2008 you must not have ridden very many banshees then. If its rockin fatty's its not that fast. edit: lots of companies out there make egt sensors that only require a hole and are held in place with a pipe clamp. Its what I run on my methanol bikes. If the holes are about 6" from the head of the pipe thats what they are for. They are hurting performance if they are not plugged. Have a welding shop close them up. I never rode a drag banshee only set up for track or trail but thank for your input Quote
