sek2dts Posted February 9, 2008 Report Posted February 9, 2008 hey everyone just finishing up my next ride and seeing what jetting other 10mill guys are running. my setup is 10mill twister crank, 68mm cubs with clean up port, 21cc domes, vf3 with stuffers, 39mm pwk's on 110 octane, and i am running a slightly undersize exhaust(shearer sb inframes) until i have extra$ for another set. i am located in new jersey at about 20-80 ft above sea level and i weigh about 180lbs. Quote
locogato11283 Posted February 9, 2008 Report Posted February 9, 2008 ive got the exact setup except for pipes... im running. 45 pilots, 160-162 main jets depending on temp. if you wanna be safe on your break in you could start at 48 pilot and 165 main, and then drop down some if necessary. Quote
