My front left headlight doesnt work. My right one works fine. I checked with a voltmeter and its not getting any power. Any idea what could be wrong?
you played with your wiring much? most likely a bad ground wire. its the black one follow it from your light to the wiring harness body and check to see if its good and connected
either ground wire or a blown bulb. i always start with the most obviouse and rule those out. i learned the hard way a few times trying to trouble shoot thing and alot of time and money later it was the most simple of problems
i only got around to testing the bad side and didnt get any readings. I will try the other side tonight to see if i get a reading out of that. Im pretty sure its not the bulb because i put in a brand new light. I didnt have much time to look at everything but i will try more tonight...
Test the ground wire in the socket to make sure you do have a ground. Then test the positive lead.
Then as the others have mentioned, test the bulb. Either switch bulbs or use you multimeter set to resistence (ohm's) to see if you have continuity across the filament.
Also make sure all the connections are together and tight.
